Evo IX STOCK TURBO E85
Old Sep 9, 2009 | 02:14 PM
Evo_TK's Avatar
English racing evo ix stock turbo e85
Ported IX turbo
Ported exhaust mainfold
Jeff Bush Ported head
Tanabe Concept G Blue TBE
ETS 3.5 Intercooler
ETS ver. 1 LICP
ETS UICP Short route
Buschur Racing Intake
Perrin MBC set at 29PSI thats all we could get out of it
RC 1000CC Injectors
GSC S2 CAMS 278 274
Kiggly high rev valvesprings
Speed Density
9:5:1 pistons
Eagle rods
ARP Head studs
Walbro 255 fuel pump
Titek 02 housing
Stock intake mainfold
I think thats it
A great English Racing Tune on E85. Thanks to Everyone at English Racing to help build my car as it is now. I think I am done with the stock turbo and time to go big.
Old Sep 9, 2009 | 02:41 PM
GST Motorsports's Avatar
Welcome to the E85 Army.
- Bryan
Old Sep 9, 2009 | 02:49 PM
YzBrad99's Avatar
Change to Hallman RX Pro. Just a idea.
Old Sep 9, 2009 | 02:55 PM
I'd lean more towards the BOV than the MBC as the culprit.
Old Sep 9, 2009 | 05:11 PM
Turbojunkie's Avatar
Originally Posted by Evo_TK
Ported IX turbo
ETS 3.5 Intercooler
ETS ver. 1 LICP
RC 1000CC Injectors
GSC S2 CAMS 278 274
Speed Density
9:5:1 pistons
Eagle rods
ARP Head studs
Titek 02 housing
I think thats it
nice. looks all most exactly like my graph. good stuff. would have expected a little more whp outta the 9 turbo though.
Old Sep 9, 2009 | 05:25 PM
ETS Michael's Avatar
Great Job ER! E85 FTW!
Michael
Old Sep 9, 2009 | 05:27 PM
BLKCarbonEVO's Avatar
That's pretty good power out of the IX turbo. That thing was not really ment to produce anywhere near 400. Your car setup is a bit different than the OP. I'll be at the dyno on Monday with Aaron and we will see what this IX turbo will do!
Old Sep 9, 2009 | 06:23 PM
JohnBradley's Avatar
We crushed this one after a prior dyno day in March. The car put down 421/360 then with a 33psi spike and since we have changed to the big S2 intake cam (278* vs 274*) and a ported head...as well as 9.5:1 bottom end.
I am still not ruling out the BOV though. The MBC was completely cranked so I am going to change that to a Hallman just to see. The thing about is this I made 438whp on our dyno with a similarly setup VIII and a Hallman and ported turbo/18psi WG that was holding 36psi spike and 25 out the top (8k). I would like to point out to anyone that reads this though that its not pressure that makes horsepower but airflow.
Old Sep 9, 2009 | 07:01 PM
fqjdmct9a's Avatar
Congrats!
Old Sep 9, 2009 | 08:42 PM
SWOLN's Avatar
*Devils' Advocate * Can you give an example of what you mean here?
Old Sep 9, 2009 | 09:28 PM
94AWDcoupe's Avatar
nice build. great looking graph. what turbo is next?
Old Sep 9, 2009 | 10:19 PM
I would go, in this order: BBK-XL or SST (just because I want to see what these new turbos can do) Red, or HTA Green!
OP what did you plan to do next? Stock frame? I really like the HTA3586/88! Sick little turbos
Edit: What was the air temp when you dynoed?
Old Sep 10, 2009 | 12:12 AM
Lucas English's Avatar
Not exactly the example I was looking for but Jake's car (the one Aaron mentioned) spiked 36psi and holds 25psi to 8k and made 438whp. Didnt log boost on the dyno of that one, but in this jpeg you see that we have 2 IXs with similar cams, tuner, SD, etc. and Thomas makes more power at less boost (1/2 pound) and Mike makes alot more torque on the spike.
A stock turbo can only make so much total airflow and boost pressure doesnt necessarily mean more power. Turbo efficiency at a given boost, compression, timing, all of that has more to do with why a car makes power (turbo being the same) not the actual psi.
The easiest way to explain it is why does a 35R at 23psi make more power than a stock turbo at 23psi? Airflow in cfm is significantly greater.
Old Sep 10, 2009 | 12:22 AM
Nice comparison lucas. I think if I had a bit more aggressive cams my topend would shine a bit better. I'm interested to see how my car will do on Monday. I guess Aaron told you I'll be down with all my new mods. Magnus v5, 3.8 Garrett FMIC, Eric's 3" external dump 02 housing, and an EBC. I think it's going to shine but I'll be lowing the boost back down to where ever it stops making power per pound.
Mikey
Old Sep 10, 2009 | 03:53 AM
Evo_TK's Avatar
Thanks yeah I will be looking into getting the magnus and a stronger waste gate soon with a tial bov, I really want to take this to the track and see how I do. I am looking at either the HTA 3582 or 86 as my next turbo
