Highest HP 4g63 engine (from 2007)
big names in their small little world
Hi, back in action.
Before 2 weeks, i test and tune an old evo8 project.
Runing methanol and a 156lbs turbo and hydraulic custom profile cams second stage.
I couldnt meausre to my dyno more than 49psi as the engine torque exceeds my dyno torque limit and shut down.
the dynoplot is only 47-48psi boost 1523hp. Its new record from a 2years old setup.
28psi ~ 1023hp. I boost it to 59psi but i could measure it.
Next post will be the 2000hp project parts and our new custom intake manifold. Dual throtle and dual plenum design also.
Spyros
Spyros
In the 2nd picture of the engine bay, it appears that you are running the stock ignition while in the 1st and 3rd engine pics there appears to be a black distributor box of some sort on the backside of the valve cover. If it isn't any kind of secret, what kind of ignition are you running?
Hi, back in action.
Spyros
Spyros
Have you already mentioned whats in the motor on this "2 y/o set-up"?
If you're unable to i understand
1000hp @ 6000rpm is actually really good, DS9 (evo9 in NZ that has the world record, 8.34 @ 169 i think) makes 1000hp @ 8000rpm on a GT4508 turbo
http://www.youtube.com/watch?v=1yBjGymUhiA
