Fast_Freddie's FP Red VDR plot...
Old Nov 17, 2009 | 08:12 AM
Fast_Freddie's Avatar
Veteran: Navy
Originally Posted by Evo_Kid
That climb at the end of the HP curve looks "unnatural".
Try adjusting the "Max RPM trim". Thats why its there.
The last RPM block in the pull was 7165 pretty much just like the plot reads...
Old Nov 17, 2009 | 08:26 AM
l2r99gst's Avatar
With VDR, you have to trim the max RPM down until the curve averages correctly. You have to remember that VDR is using mathematical averaging over a number of cells, depending on the smoothing. So, you can't go right to the edge of your RPM from your log, or the averaging gets screwy at that point. Usually 100-300 RPM before the end of your pull works out well.
Old Nov 17, 2009 | 12:25 PM
Evo_Jay's Avatar
It doesnt matter. Read this..
Old Nov 18, 2009 | 08:30 AM
Veteran: Navy
Updated with boost plots
Old Nov 18, 2009 | 02:26 PM
Evo_Jay's Avatar
Why didnt you fix the VDR chart?
Old Nov 18, 2009 | 03:40 PM
Veteran: Navy
I am gonna go do another rip tonight up to 7800 then post that up... with new boost plots too...
Old Nov 18, 2009 | 05:53 PM
Evo_Jay's Avatar
But you can just take the plot you already have and just use the "max RPM trim" to fix it and then it will be fine. No need to make another run.
Old Nov 18, 2009 | 07:33 PM
Veteran: Navy
Okay everything updated
Old Nov 18, 2009 | 08:06 PM
Evo_Jay's Avatar
Nice.
Your using the profec spec II for boost control right?
Old Nov 18, 2009 | 08:17 PM
BLKCarbonEVO's Avatar
^ Fred was just running 18psi wastegate pressure. Not sure if he has the profec on.
Old Nov 18, 2009 | 08:28 PM
Evo_Jay's Avatar
?? Logs say he was boosting 26 tapering to 23/24??
Old Nov 18, 2009 | 08:56 PM
Veteran: Navy
Nice.
Yes profec b spec II... When we were ironing out the tune we were running wastegate pressure and I was creeping to 27... but it helped us hold load a bit to tune midrange better. Then Sunday I turned on the boost controller, and we finished the tune ...
STWHY?
Sep 29, 2010 01:38 PM
Fast_Freddie
Sep 26, 2010 02:23 PM
vegasboy301
Dec 12, 2005 06:30 AM
vegasboy301
Nov 26, 2005 05:14 PM
snoop
Apr 12, 2005 10:26 AM
