570whp 23psi 3586
Old Nov 24, 2009 | 01:25 PM
JohnBradley's Avatar
Originally Posted by Turbojunkie
nice. makes we want a hta86 set up sooooooooooo bad.
Now we know where your 9.5 will let us go on gasoline
Old Nov 24, 2009 | 01:32 PM
BLKCarbonEVO's Avatar
Aaron how is the longevity of your 2.2lr at 9.5k? Is that considered fairly safe iyo?
Mikey
Old Nov 24, 2009 | 02:03 PM
Its not any worse than a stock stroke 2.0l. I dont think its unsafe but things dont last long strung out for extended periods of time. That said I am not afraid to rev it out though
ETS Michael's Avatar
Aaron -
Great Job! Your car is making amazing power at that low boost level. This car is going to be a beast once it gets on a E-85 and higher boost.
Nice Job!
Michael
Old Nov 24, 2009 | 03:18 PM
Evo_TK's Avatar
Very Nice!!!
Old Nov 24, 2009 | 03:36 PM
RAbishi's Avatar
Wow impressive results! I have been curious to see what higher compression would do on pump gas.
Old Nov 24, 2009 | 04:00 PM
^ allow you to not run as much boost! the Hcomp will really come into play when Aaron runs E98 tomorrow
Old Nov 24, 2009 | 04:24 PM
jid2's Avatar
Nice son. That's an S-ton of torque at 23 psi. What's with the dip at 5700 RPM, just an area that needs timing?
Can't wait for the E85 results. I will also need a ride.
Old Nov 24, 2009 | 05:02 PM
kouzman's Avatar
Thats sick power curve especially for the boost!
How much do you think the high compression motor helps with that? Is it true the about 10% in power and torque for every unit of compression?
Old Nov 24, 2009 | 06:26 PM
gsrboi80's Avatar
Thats a *** load of power for 23 psi. Good stuff Aaron and turn that **** up
Old Nov 24, 2009 | 08:12 PM
BomBom's Avatar
nice numbers
Old Nov 24, 2009 | 09:07 PM
Well its not going to ethanol tomorrow as planned. Instead I want to do 2 things first. We got our order of MAP sensors in so the dyno will log boost now, and that dyno sheet isnt really finished in my opinion. Peak power and torque are good and all but there are those dips that I notice (maybe no one else does, not sure) from low timing. Between the fact that I want a dynograph with attached boost and it has to go back on anyway, I am going to run one more tank of 92 through it first. It is only 115 miles old so its not gonna hurt anything by waiting.
Secondly I havent gotten any knock yet. The car has just continued to make power as I add timing to it (compared to 85mm 2.0L timing) over where it was. I take this as evidence I can keep going with the boost so in order to make it worth it strapping it down I am going to keep going up with the boost and see what happens. I am not sure how far its gonna go or if its already at the edge and I just dont know it yet. Based on what I have seen with my stock motor I think I can still keep feeding it boost (that one did run 32 at one point) despite the compression.
....Or I could be totally wrong. We'll see I guess.
Old Nov 24, 2009 | 09:09 PM
I know this is a fluke, but it so happens that if you take my orginal 23psi number (496), multiply by it by the percentage of displacement increase (496 + 49.6=545.6) and then use the already extensively proven hot rod rule of 4% per full point (545.6*1.04=567.4) and you get pretty close to my number.
Old Nov 24, 2009 | 09:11 PM
Looking at the graph I noticed:
5500- needs 1*
5750- needs 2*
6000- needs 1*
7250- needs 1*
That should smooth it and then I am going to add boost
Old Nov 24, 2009 | 10:08 PM
GotWheelHop's Avatar
Damn Aaron. Graph looks delicious, and looks like a 2.2 will be the way to go when my 2.3 craps out. Great numbers, regardless. If you get a chance to test on ethanol anytime soon, text me the dyno results, if you don't mind.
