FP black and some E85
Old Nov 28, 2009 | 10:26 AM
BenJ's Avatar
Originally Posted by 94AWDcoupe
520 sounds much better. thats a huge knockdown of power for reliability. E85 is easy on engine. would be good if you could post graphs
Once I get the bottom end built and up the boost, this turbo will be close to 600 on the mustang dyno no problem. And while E85 itself may contain certain properties such as added cooling effect, the end result of a setup with over 450 wtq on a mustang dyno is not so friendly to the stock bottom end.
Old Nov 28, 2009 | 11:43 AM
scheides's Avatar
EvoM Moderator
Thanks for posting the graph! You can tell this thing has a lot more in it. Can you tell us more about your intake manifold? Is it a ported stocker, a SMIM, or what?
Old Nov 28, 2009 | 12:07 PM
red03evo's Avatar
Nice power. Congrats on the setup. Enjoy the car.
Old Nov 28, 2009 | 12:33 PM
project_skyline's Avatar
Originally Posted by BenJ
The injectors are too small....I'm running them at the limit, which is why I will be putting in some 1200+cc's in the coming weeks.
If your going to upgrade why not get something with some over head, for e85 1650's minimum.
Old Nov 28, 2009 | 12:58 PM
s.e.a.n.'s Avatar
Get some 1600cc you're gonna run outta fuel with 1200cc also
Old Nov 28, 2009 | 04:44 PM
Liqquid's Avatar
look into the ID2000's if you have the cash... that power is excellent at 29psi with stock head and ecu.. especially when this turbo can go so much higher when you are ready!
I agree whole heartedly with keeping it turned down till the bottom is built.. don't make the same mistake I and a few others did lol...
Old Nov 28, 2009 | 05:06 PM
Evoryder's Avatar
What does full spool mean? I know start spool...and full boost.
Old Nov 28, 2009 | 05:47 PM
BenJ's Avatar
full boost, I apologize for any confusion. I've been eying those ID2000's and I'm thinking about pulling the trigger on them. My intake manifold is made by Reese Tuning in San Diego and it is like a Wilson manifold on crack. On a flow bench it outflowed the wilson V3, or whatever their highest version is by an average of something like 5-10%. If you want more info on it contact Reese Tuning but it isnt cheap (around $1200) and it is modeled off of the stock intake manifold but they add material to certain areas so that they can increase the volume and a bunch of other stuff...definitely a nice piece.
Old Nov 28, 2009 | 05:48 PM
BenJ's Avatar
Thanks for the comments everybody. I'm fairly confident that this turbo on a built bottom end will/can hit 600 on a mustang dyno very easily.
Old Nov 28, 2009 | 08:14 PM
scheides's Avatar
EvoM Moderator
Any chance you have a boost profile? It looks like boost is purposefully left low from the 4000-4500 range or perhaps timing is extra low, based on the torque curve.
Old Nov 28, 2009 | 09:22 PM
BenJ's Avatar
the timing is very low according to the shop that did the tune. I'm not very hip on the whole tuning thing but I did watch him take a lot of timing out out to bring the power down to be safe on the stock block.
Old Nov 28, 2009 | 09:24 PM
BenJ's Avatar
I'll ask about getting the boost plot as well
Old Nov 28, 2009 | 09:46 PM
AlligatorMan's Avatar
Why don't you just turn down the boost instead of takin out so much timing?
Low timing can cause really high EGT which isn't easy on the motor, either.
Old Nov 28, 2009 | 10:31 PM
James Reese's Avatar
I tuned this evo. We are speaking of an engine as well. A motor is powered by electricity. The tune on this car is very conservative and has plenty of room left to make power. Please do not comment Alligator, as you were not there and have clue what the ignition map looks like. Thanks. Also just to clarify, the boost simply spiked 29psi and held 27psi. We are using a GM solenoid. The injectors were tapped. Another reason why we left the boost alone.
Soon be installing a BR2.3L and SD conversion. I will keep everyone posted. This car is a true street car and very capable of more power.
Please do not delete this as I am not advertising business. I am simply correcting someone's arrogant remark about something they do not know.
James Reese
Old Nov 29, 2009 | 07:10 AM
batty200's Avatar
I tend to agree with the poster above that if the car makes good power with proper timing at lower boost levels just leave it at a lower boost. Pulling timing to reduce power is not as efficient and doesnt make a lot of sense. Especially on an E85 car where knock isnt an issue. Just turn the boost down to a stock block friendly level. MBT is easier on the engine and uses the least fuel.
