FP black and some E85
Old Nov 29, 2009 | 07:22 AM
  #31
BenJ's Avatar
Knock is always an issue with pump gas. You never know if you are getting true E85 or some other percentage. It would be one thing if I was running VP fuel where you know what your getting everytime, but with E85, you simply do not.
Old Nov 29, 2009 | 07:23 AM
  #32
BenJ's Avatar
And James, the car is badass!
Old Nov 29, 2009 | 07:51 AM
  #33
Gary@MellonRacing's Avatar
great power , and still room to grow man
Old Nov 29, 2009 | 08:05 AM
  #34
scheides's Avatar
EvoM Moderator
Originally Posted by James Reese
I tuned this evo. We are speaking of an engine as well. A motor is powered by electricity. The tune on this car is very conservative and has plenty of room left to make power. Please do not comment Alligator, as you were not there and have clue what the ignition map looks like. Thanks. Also just to clarify, the boost simply spiked 29psi and held 27psi. We are using a GM solenoid. The injectors were tapped. Another reason why we left the boost alone.
Soon be installing a BR2.3L and SD conversion. I will keep everyone posted. This car is a true street car and very capable of more power.
Please do not delete this as I am not advertising business. I am simply correcting someone's arrogant remark about something they do not know.
James Reese
Just to get an idea of how conservative tune this is, would you mind sharing any rough timing numbers for this 450whp tune? Also mind sharing a plot that was over 500 and details? Also curious about the torque, see how during onset it come up, then rises again 500rpm later? This is not typical in my eyes. Is it a trait of this turbo coming up to full shaft speed or timing just being extra low around 3500-4000?
Old Nov 29, 2009 | 08:15 AM
  #35
vaboostn33's Avatar
is this stock block and stock head? (obviously with cams ect ect)
Old Nov 29, 2009 | 08:18 AM
  #36
BenJ's Avatar
stock block and stock head minus cams and springs.
Old Nov 29, 2009 | 08:32 AM
  #37
tchouko's Avatar
Wait...so stock block stock head...and you pushing that much with just the FP black...wooooooooooooooow
Old Nov 29, 2009 | 08:52 AM
  #38
BenJ's Avatar
yes sir...well, I have upgraded head studs too, but other then that, all stock.
Old Nov 29, 2009 | 09:09 AM
  #39
Aby@MIL.SPEC's Avatar
Great power!
That must be a blast to drive.
Nice work james.
Old Nov 29, 2009 | 09:13 AM
  #40
BenJ's Avatar
yeah, it's pretty fun.
Old Nov 29, 2009 | 10:12 AM
  #41
James Reese's Avatar
To everyone that thinks and is acting as if I took 10 degrees out of the ignition map are worthless your thoughts aren't needed. Thank you. I simply took three degrees out and left the tune spot on KNOCK FREE. Still ran 29 psi held 27 psi by redline.
For reference. The igniton map looks like this. 3* at peak torque and 11* at redline.
AFR was a solid flat 11.8 throughout the entire powerband. Any more questions?
Regards,
James Reese
Old Nov 29, 2009 | 10:17 AM
  #42
BenJ's Avatar
and there you have it!
Old Nov 29, 2009 | 10:28 AM
  #43
Liqquid's Avatar
Good points here, if I remember correctly, the E75 would have a different burn rate than the E85 and having a little less timing would help if the fuel ends up being not quite what you were tuned on. I know when I was on the dyno I had measured E85, but when I went to the track we had to pull a couple degrees for the "E85" from the pump in Norwalk
Old Nov 29, 2009 | 10:30 AM
  #44
localtoys73's Avatar
you should invest in the ethonol content analyzer
Old Nov 29, 2009 | 11:37 AM
  #45
RyuEvoIX's Avatar
James Reese
James, what does a typical 450whp evo on your dyno translate to trap speed wise? Thanks in advance.
