Top Level + Ets 37r kit + Aem ems= Over 700hp!!
I never had a chance to go into this build into detail,,, so here we go!!
2006 evo ix
Top Level spec build on the 2.0 motor
Top Level spec fuel system with twin pumps
Ams vsr intake mannifold
Ams Race Ic
Stock ignition + Hks dli
Kelford 272's
Stock TB
Ets t4 37r kit
Aem ems
Buschur Exhaust
E-Spec Tuned
On 93 pump gas@21 psi (Wastegate) this car made 490hp first pull from the "road tune"... We brought the car to the dyno low on gas, finished off the pump map, and then loaded in the 'go juice' for the race map.
734hp...c-16...Smoothing 0
Another "Average Joe" loose in the streets.
2006 evo ix
Ams Race Ic
Kelford 272's
Stock TB
Ets t4 37r kit
Aem ems
Buschur Exhaust
E-Spec Tuned
Thanks Buddy!!
41-42 peak dropping to 37-38
This dip was more related to the tires spinning on the dyno.... Allow me to share some logs with you of boost, air temps, rpms, and vehicle speed,,,,
This shot is at about 92mph @ 7500 rpms
You can see the mph ramp up to 99mph @ 7700rpm as the tires spun...
And then as the tires caught traction the mph drops back to 93mph @ 7900rpm,,,
Normally when misfires occur the opposite happens,,, you'll get a drop in vehicle speed on the miss, and then it will pick the speed back up as the ignition catches up.
On a side note,,, I'll share some findings on the AMS race intercooler...
Start of pull,,,
End of pull...
Ouch!! That's 20 degrees in 1 third gear pull?? This cooler flows like a bat out of hell, but needs some help in the temp control dept vs the buschur or ets products that I've tested at these boost levels on similar combos.
i have personal seen this car, this is one amazing setup and an even better job of getting the most out of this combo by e-spec... great job urck nice graph.... hows it feel to be on the top charlie?
Its about time u post up some of the beautiful art work
Keep them comming sir its time to shine
Now show them how E-SPEC and TOP LEVEL gets it popin
