Mitsi evo8 2.3 BBK Full
Old Mar 13, 2010, 05:11 AM
  #31
evodom1's Avatar
If you change stock o2 to aftermarket - you'll have gains in top end (actually improve 5.5-6.5r RMP) but torgue will drop in the middle. There is always a choice My choice is torque...
Old Mar 13, 2010, 07:03 AM
  #32
sparky's Avatar
Originally Posted by evodom1
If you change stock o2 to aftermarket.... torgue will drop in the middle.....
Are you comparing a stock unported housing to one particular aftermarket O2 housing, or O2 dump? Exactly, how much of a torque drop are you observing in the midrange, when you say, "drop in the middle"?
Old Mar 13, 2010, 07:18 AM
  #33
evodom1's Avatar
stock compare to aftermarket O2 housing.
the drop in torgue in % is the same like raise in HP
Old Mar 14, 2010, 07:39 AM
  #34
cosworthbg's Avatar
that's interesting, will see on the dyno soon.
actualy we will remake an ebay aftermarket o2 housing to 3" bend with screamer pipe.
the most interesting is, now the car is without air box, just adapter and cone filter and the top power gone somewhere , probably due to knock cut above 4000-5000 RPM and the leaner AFR.
Old Mar 22, 2010, 01:55 PM
  #35
cosworthbg's Avatar
Hi to everyone
Some road tests after the second dyno with cone air filter, bigger 3" o2 housing and screamer pipe.
The new dyno graph is slightly higher at the top end, the boost also.
Have to add it soon.
The strange thing is the knock control retards the ignition advance doun to 1-2 degrees at the top end.
Forgot to mention previously, the dyno graphs are CF 1.01
Old Mar 22, 2010, 04:12 PM
  #36
GST Motorsports's Avatar
Your EGT's must be going through the roof...
- Bryan
Old Mar 22, 2010, 05:41 PM
  #37
cosworthbg's Avatar
EGT is going up to 900 degrees C when floor it
Old Mar 22, 2010, 10:52 PM
  #38
FQ4OO's Avatar
very nice responsive setup! Im thinking of going a similar setup with mine.
eve-slow
For Sale - Cars For Sale
48
Aug 25, 2012 11:08 AM
Mr. Move
Nov 4, 2011 10:09 PM
Chadbee@Forged
May 26, 2011 02:47 PM
rish197
For Sale - Wheels / Tires
Sep 4, 2010 11:01 AM
edwinisdumb15
Aug 28, 2010 10:26 AM
Quick Reply: Mitsi evo8 2.3 BBK Full
