623/477 on 92 octane at 25.5psi?
Old May 3, 2010 | 10:04 PM
JohnBradley's Avatar
The 3586 is amazing. So to the dyno graph-
Mods for those that havent followed the various incarnations.
ER MIVEC 2.4 long rod 4G64
ER ported MIVEC cylinder head
ER modified MIVEC cam gear
Supertech inconel exhaust valves and nitrided intake valves
JE 9:1 pistons
GSC 156mm rods
GSC custom cams
Magnus cast intake manifold
ETS FP3586 kit, T3 .82 A/r single scroll
ETS 3.5" exhaust
ETS 4" intercooler and Magnus specific upper intercooler pipe
Kiggly Racing Valvesprings
Omnipower 4 bar MAP sensor
Stock ECU SD
Magnafuel 625 Pro fuel pump
Aeromotive FPR and fuel rail
-6AN fuel lines
AEM Tru-boost EBC
92 octane
I think thats all the big pieces. Of course any project that takes on a shop car status requires that everyone that has helped be thanked as well. Lucas thanks for all the ideas you have let me bounce off you. Jeff for the engine assembly and cylinder head, TJ and Jake for the ideas and implementing them.
This tune is really soft believe it or not as the car only has 424 miles on it. There is about 5* of timing out of it down that I could add in but I am trying to keep it civil until I put it on E85. I will get a little more aggressive with it then
EDIT - UPDATE WENT TO THE DYNO ON E85
Old May 3, 2010 | 10:10 PM
R/TErnie's Avatar
badass Aaron I'll need a ride in this one! Props
Old May 3, 2010 | 10:31 PM
Thanks
Here is the datalog for those interested-
Old May 3, 2010 | 11:57 PM
BLKCarbonEVO's Avatar
Subscribed. Congrats again Aaron. This thread makes me excited for the next few weeks
Mikey
Old May 4, 2010 | 12:52 AM
GotWheelHop's Avatar
Thanks for the text Aaron. Being able to see the graph is much better though.
Old May 4, 2010 | 12:56 AM
yahu's Avatar
Wicked! Funny, I was following this through your 2.2L build thread.
I look forward to the weekend, and hope you get ethanol in there for the festivities!
Old May 4, 2010 | 07:15 AM
FathouseFab's Avatar
Damn nice my man! Now put some corn in it!
Old May 4, 2010 | 07:16 AM
AlligatorMan's Avatar
Thanks for posting the datalog - it is interesting to see.
Add a degree or two from 5600-5800, correct?
Whats the purpose of ATDC values? Spool up the turbo or fend off knock or both?
How's the EGT during this period?
Old May 4, 2010 | 07:48 AM
High_PSI's Avatar
Yeah well a 2.4 helps ALOT.
Old May 4, 2010 | 08:17 AM
dsmfan95's Avatar
Looks like it's 584 @ 22psi lol.
Old May 4, 2010 | 08:48 AM
Fast_Freddie's Avatar
Veteran: Navy
Good stuff Aaron!
Old May 4, 2010 | 09:39 AM
R/TErnie's Avatar
Cam timing cause the dip at 5700 or so?
Old May 4, 2010 | 11:06 AM
jid2's Avatar
Very meaty.
Now don't touch the pump-tune, just drive it until it is on the gas light and head straight for the E85 - then turn up zee boost and get after it.
Old May 4, 2010 | 11:19 AM
PeteyTurbo@KHC's Avatar
Looks just like a small amount of boost fluctuation, but it is very minimal.. Thats a pretty interesting setup guys
Old May 4, 2010 | 01:07 PM
boostedwrx's Avatar
SICK!!! On ethanol this thing is going to dominate!
