Comment on my (FP Black & HFS-6 Meth) Virtual Dyno Graph (Bonus: fun FP Red comparo)
So for ~ the past month, I've been tuning my stock block Evo IX with an FP black and meth.
Let me start by saying this is the first car I've ever tuned. Learning to "tune," on an aggressive setup like this has been a challenge to say the least. But, after hours and hours and hours and hours of reading and a huge number of logs, I've made some good progress, at least in my opinion. (And i only had two logs with knock greater than 10 ).
Here's the current Virtual Dyno graph at 31psi:
EDIT, other graphs to come. Tire size was a tad off and, unfortunately for me, graph was reading high.
Now for reference, here was the same car on a totally different tune (not done by me) on an FP Red and a high flow cat, BUT somewhere around, I'm guessing 37psi; my boost gauge would quickly max out at 35 psi....).
Note, we all know comparing dynos isn't a good idea, especially digital ones to physical ones, lol, but as you can see, I lost A LOT of tq. (both have smoothing set to 2 and the latter is on a dynojet, for whatever it's worth).
I suspect nearly all the tq was lost from the ~20% difference in peak boost (31psi vs 37+?)
In conclusion, I'm pretty proud of my tune. I'm certainly not done, but I'm about 90% of the way there. I may actually retard the timing a tad, and bump the boost by 3psi and see where it takes me. OR i may just leave well enough alone and start saving for a new clutch and built 5 speed. I'm sure there are many of you out there making sooo much more hp, but yeah, it is what it is lol.
I'd also like to note that with the new tune, I'm getting really great gas millage.
Constructive criticism is welcomed.
Major parts include
Cosworth M2 Cams
FIC 850cc Injectors
ETS 3inch FMIC
Minor stuff include:
FP 18psi Wastegate
FP Intake Pipe
Forge RS BOV
ETS LICP
TurboTrix UICP
Amsoil Cone Filter
Silicone Hoses Cajun Power T-Bolt Clamp Kit
Mil. Spec 65 MM throttle body
Hallman MBC
PPI Ported Intake Manifold
Ported exhaust manifold
50/50 water meth.
Comes on at IDC % of about 22% and matches injector load the whole way.
I have nothing to compare that to, but it seems a good deal of meth. Trying to make the AFRs smooth at that point was tough at first.
You have to remember it's his first time tuning also on the red he was running 37 psi that's a big difference also not to mention his stock block is gonna last longer with the low tq ramp then the red that had some monster tq which = bad news for the wrist pins and rod bolts.
1. Imagine if I set the black up for 37psi like the red? Both turbos thrive in the mid 30's. I'm pretty sure I'd have more tq than the red had hp lol
2. I'm not sure how the hfc and smaller red were affecting the ratio of tq to hp.
I will agree, the red's kill-mode tune would be faster in the 1/4, but I THINK an equally punishing tune would walk the red at literally every point on the graph.
Anyone agree or disagree?
Well few quick thoughts on that (and you may be right).
1. Image if I set the black up for 37psi like the red? Both turbos thrive in the mid 30's. I'm pretty sure I'd have more tq than the red had hp lol
I have to disagree with 94AWDCoupe. Yes, the red has the better powerband, but considering the stock block, it's going to stay together for longer on the black provided you don't start revving it out to 8000+.
Now if you had a built bottom end to handle to torque and only wanted low 500s, yeah the red is the better turbo. Although, the black really isn't giving up much other then at the peak torque, which is obviously the higher boost.
But Dynojet vs. virtual dyno... who knows how it would look on a dynojet.
4doorstreetbike, you are forgetting his is running 6 psi+ less boost on the black. If the boost was the same, I think the black would be even or above the Red at 5500 and well above at 7500.
True but he was talking about the way it sits now!
But that graph you're looking at for the red was the "kill" tune on 37psi. What I was trying to say was IF I tune the black to a "kill" setup, i.e. 37psi or 460tq (whichever came first), it would probably be faster than the red at nearly the entire rpm range.
That was the point I was trying to make, for better or worse.
