Fp black. 522hp at 25psi.
Got the car finished thrusday night. drove right to the dyno.
Things to note:
Stock intake manifold. throttle body.
unknown Front mount. 3inch core. (had a leak problem with my ETS)
Stock lower coldside pipe. with stock route upper.
SINGLE walboro. stock fuel lines. fuel rail. FPR.
Car put down 522hp at only 25psi. on pump gas. car was making more but there was a boost leak that we couldnt find (it was 3am). we were having problems with the TRU-boost. so we put in a MBC. there is still plenty left in the walboro for more.
im going to go over everything. get a Buschur FMIC with shorter piping. clean up everything up. turn it up on pump. than go with c16.
Things to note:
Hmmm. FPBlack comparison on our dyno-
I have done 490 at 29 on pump, but that was with a V5, S2s, built 2.0 motor, etc. We did 525@28psi on 92 octane with all the same mods on a built 2.4 as well. Knowing what it took to make 613@25psi on Mikey's E85 2.4 monster I really have to find it hard to believe this was legit on the operators end of the dyno session. What does a bone stock Evo, with the same correction factor your car used, make on this dyno?
aaron
aaron
Another interesting dyno plot. 522 @ 25psi...a bunch of stock pipes/no porting. and a boost leak lol ..amazing. I would love to see this car on a dynojet. I'm thinking this car is at least 80whp higher than it really is.
motor is a built 2.0 10:1 compression. buschur stage 3+ head. tomei 280's. buschur ported exhaust mani and a ported black.
LOL @ this. 522 on this type of dyno with standard cf is not even possible with 92-93oct since these dynos read lower then even mustang dynos. im guessing the CF is so high that its a joke. It must be D* M***** (censored because the place isn't even worth mentioning.)
Even dynojet CF, 522 @ 25psi with that kind of torque curve? i call bull**** 100%. nice try but it wont work on this forum, we are not idiots.
I'm willing to bet this car will barely make 400whp on a dynojet as it sits @ 25psi.
Things to note:
Things to note:
seriously if you cant tune cars then close the ****ing shop. anyone that has to raise CF to make more power cant tune for ****.
If it was creeping bad out the top I can believe the power and powerband. It would look something like this-
23 or 24 for most of the pull and then creeps to 29 by redline. Powerband looks somewhat similar. This was a 9.5:1 motor as I recall.
aaron
aaron
i dont know what shop you are referring too. PM me if you have problem though im curious.
im clearly not representing anyone or promoting anyones work. this was done privately.
