My VD Results Thus Far 525/399 on wastegate
Well finally got some miles on the new motor and decided to do a little break in tune until it gets on a real dyno. As of now the car is just on wastegate pressure (25psi) AFR's are 10.9-11.1 with 10 degrees timing at redline with 0 knock.
Also we weren't reving it out high at all. Redline was set to around 8k.
Also I realize these numbers could be taken with a grain of salt, I will follow-up soon with an actual dyno sheet.
Important Mods
Built 2.0
5 Angle Valve Job (no porting)
Eagle Crank
Eagle Rods
Cosworth Bearings
Wiseco HD Pistons
ARP studs and bolts all around
6765 Billet (.82ar) (Journal Bearing)
GSC S2 Cams with Fidanza Gears set to 0/0
Dual Valve Springs/Retainers
ETS 3.5" Core
JMF 3" piping
Stock Intake Manifold/Throttle Body
Stock ECU/Maf
Important Mods
Built 2.0
Eagle Crank
Eagle Rods
Cosworth Bearings
Wiseco HD Pistons
ETS 3.5" Core
JMF 3" piping
Stock ECU/Maf
No reason to disbelieve a 6765 making 500+whp on 25psi of boost. Why such a high base boost level? With external gates on t3 turbos you can run a relatively low spring pressure and still hold a lot of boost out the top. I have run over 30psi on a 5spi spring in TiAL 38mm wastegates.
Thanks for the info tscomp maybe ill see what a little more timing will do.
Batty - I went with a very tight spring because from what ive experienced it can help with spool up a little especially it being such a large turbo. Also not to mention it was already on the manifold I got haha
I did the same thing on the spring yours is a bit stiffer then mine that doesn't sound good.
Mine on straight wastegate is 22 psi and my * is a bit low around 12*.I would go s.d with your setup it would benefit you alot.As for the * goes it's rather low but a nice base for what your doing right now.
I would leave it till your tuner bumps it up himself and enjoy the nice power you have..
^^^^ haha..
Yeah I hear ya man, it feels stout where its at right now.
I will more than likely being doing s.d along with upgrading my intake manifold and throttle body in the near future.
black E
Evo X Dyno Results
Oct 22, 2014 07:00 AM
maperformance
Oct 14, 2008 04:14 PM
