CBRD does it again. BBK full retuned... More power!!
Old Nov 15, 2010 | 01:21 PM
dbsears's Avatar
Originally Posted by boosted91t
Scheides - the synapse dv was the only addition power wise. You have the same reaction I did.
Thanks pizzaman, wow that puts the power into perspective doesn't it. Z06's are no joke
I am extremely happy with the exedy, Best clutch I have had so far in any vehicle. Little chatter with huge holding capacity in comparison with the stock clutch which is a perfect combo.
Its amazing how much the stock DV can leak at higher boost and give up power. Switching to my APS was like night and day how much stronger my torque came on and the boost held up top.
Don't want to derail the thread but how much chatter does your STG2 have? Been seriously considering that myself as I don't think a little over 400whp warrants a twin disk for myself atleast.
Old Nov 15, 2010 | 01:37 PM
boosted91t's Avatar
That was my thought on the twin disc too. I like a solid pedal and the twin disc cannot do that for me. The chatter is not bad at all, you can daily drive this car if you wanted to. The car shifts soo smooth its unreal.
Old Nov 15, 2010 | 01:52 PM
TK40's Avatar
Your car is unreal man, you truly have a wonder from the factory! That is awesome!
As a comparison, I made 410whp with a BBK-B on Chads dyno, and I have slightly more bolt ons than you. I can't even imagine what you will make with a B!
Old Nov 15, 2010 | 02:07 PM
ghammer2's Avatar
I'm going to point everyone to this thread when I see them asking "I want a 400whp DD what do I do!?!"
Fantastic car/mod list. Congrats!
Old Nov 16, 2010 | 04:24 AM
Craig King's Avatar
How much power (roughly) do you think the Kelford 272's are contributing? I'm curious what a graph would look like for a car with the same mods, minus the cams.
Old Nov 16, 2010 | 07:21 AM
stryker9's Avatar
123 trap with some tires you would be low 11's
Old Nov 16, 2010 | 08:37 AM
CBRD's Avatar
I think these cams are worth a healthy 20-25whp...
this is car is just nasty...
PERFECT STREET car in my opinion!
Old Nov 17, 2010 | 06:43 AM
berns's Avatar
how is the pedal feel on the Exedy Stage 2 compared to stock?
Sick numbers by the way. Your car seems to make a decent bit more power than any other I've seen, especially on Chad's dyno.
Old Nov 17, 2010 | 07:07 PM
boosted91t's Avatar
stryker9 - Yea the car will definately do a low 11 with more seat time. I was launching with the 2 step at 4900, and slipping the clutch nice and easy so it was far from an agressive launch.
berns - The pedal feel is excellent, great feedback through the pedal. The pedal pressure is not near as light as the stock unit but not too hard where driveability suffers. I think it is a perfect mix. I would definately recommend this clutch to anyone near my power level.
Old Nov 19, 2010 | 03:35 PM
catman78's Avatar
I was quite surprised about how my car felt after replacing a stock 9 diverter with a Synapse DV. Seemed to hold boost stronger.
Well worth the $ for a 10 minute fix.
Old Nov 20, 2010 | 02:41 AM
catman78's Avatar
boosted91t
Did you change the flywheel when you did the clutch?
I'm looking to go with Exedy Stage 2 and ACT Prolite flywheel.
Old Nov 20, 2010 | 08:15 AM
crand002's Avatar
What wastegate actuator is the car using?
Old Nov 20, 2010 | 03:07 PM
boosted91t's Avatar
I would not recommend using any lightened flywheel with the exedy stage 2. I couldn't imaging how much the driveability would suffer. I used the stock flywheel and would recommend the same.
Stock evo 9 wastegate actuator.
Old Nov 20, 2010 | 04:12 PM
Craig King's Avatar
OP, what clutch were you running prior to your Exedy?
Old Nov 22, 2010 | 06:24 AM
boosted91t's Avatar
Original stock clutch until shortly after the bbk install lol. She was babied for the first 58k miles
