EVO8, FP Black and pump gas.
Dyno'd a car this morning that made great power on pump gas and thought I'd put the sheet up. The car has been around for a long time and use to belong to another customer. Way back before it was common to go fast on pump gas and stock style turbos this car ran 10.8 at 131 mph on the original FP Green, stock short block, stock head and pump gas with an SMC alky kit. That was at full weight and on street tires. The car has gone through some changes over the years.
It is now equipped with a BR Stage 3 shortblock, BR Stage 3 head, BR exhaust, BR Race FMIC, BF272 cams, ID2000cc injectors, BR double pumper, Forge manual boost controller, BR ported intake, BR 65mm TB, BR COP ignition, AEM EMS.
Below is the dyno sheet from this mornings tune. 30.2 psi peak boost. 20 psi hits at 3750 RPM, which is very good. At 7700 rpm the turbo is still holding 28.23 psi, so the boost is flat as the 30.2 is a bit of a bump in the middle of the run. AFR's are mid 11's.
The car layed down 469 whp and 400 ft lbs of torque.
Enjoy.
Enjoy.
