FpBlack === One mean pump gas turbo!
Old Sep 15, 2013 | 06:20 PM
  #76
KingTal0n's Avatar
People keep saying "pump" But are they talking about 93 or Ethanol?
I just cant imagine 30psi of boost on 93 octane pump gas. Or... can I?
Old Sep 15, 2013 | 06:47 PM
  #77
tscompusa's Avatar
93 octane. not all 93 octane is created equal though, so your results will vary based on the quality of the fuel in general.
Old Sep 16, 2013 | 08:40 AM
  #78
Not4Sale's Avatar
E-spec at it again! From 5k rpm to 8k rpm it going up 100whp, such a smooth tune. i expect nothing less from my dude Erkel
Old Sep 16, 2013 | 11:26 AM
  #79
KingTal0n's Avatar
wow. Okay, 93 octane and 30psi.
The compression ratio is around 8:1? Just guessing.
I have experience with 2.0L sr20det engines. The most I would trust 93 octane to is around 22psi on most 86x86 engines (sr20/2jz). I feel bad enough at 18psi actually.
Is this a normal routine... with this engine, to push 29psi on 93 octane fuels? I have heard about it, in fact that is one reason I came to this forum; I am investigating this "rumor" which apparently is in fact truth.
has anybody tried pushing an engine like that for 50,000 miles in a daily driver? It seems... abusive. Very curious about the longevity.
Old Sep 16, 2013 | 12:39 PM
  #80
94AWDcoupe's Avatar
not in florida. our 93 is crap gas. I dont think 450whp is safe
Old Sep 16, 2013 | 02:19 PM
  #81
boostedwrx's Avatar
The Cenex 94 I used to get had ~20% ethanol content. Made 450 on the BBK with that pump gas. Too bad they replaced it standard 92. Anyone in the Midwest still get CHS 94?
Old Sep 16, 2013 | 03:13 PM
  #82
Darksun280's Avatar
That's that amount of boost I run on my X. Dyno's vary too much to say but I've pulled 101 1/8 and 129 1/4 traps on pump at the track. Im in a heavier car then an 8-9. 133+ on pump for an 8-9 seems possible.
Old Sep 16, 2013 | 08:52 PM
  #83
High_PSI's Avatar
I run 29PSI on my Red on 93 octane, I make 460WHP. Maybe 124-126 Traps with that. I have very mild cams, maybe some bigger cams would bump me up to 500WHP or so.
Old Sep 16, 2013 | 09:36 PM
  #84
KingTal0n's Avatar
Good lord that's a killer amount of boost pressure guys.
So help me understand your engines a little better, if you dont mind? I think you are all using 2.0L (122 cubic inches) 4-cylinders. I dont know what "red" means or "8-9" is that the generation?
Your compression has to be 8:1 or close to it. Any body running 9:1 though? I am still strictly talking 93 octane. I know you can get away with 10:1 or higher using E85.
And rpm is biggest factor at the end of the tunnel. At 7,000rpm and 17~psi you should be able to squeeze 350rwhp out of a 2.0L assuming 100%VE or nearly that.
because, 122x7000/3456 = 247CFM * (.069) * 2.2 = 375BHP or 360rwhp
Around 350rwhp should be possible. And because math is not good at real world results here is a real world result
Heres a 2.0L engine making 350rwhp before 7,000rpm and turbocharger efficiency is dropping out along with VE so power peaks and holds. Its reading about 10hp high because its set to "STD" but if it was uncorrected it would read around 350 wheel. Stats are (8.5:1 T25 flange turbocharger 256*Duration camshafts 4-valve head stock valvespring and greddy intake/tomei exhaust manifold)
It was running about 17PSI at the intake manifold, tuned on 93 octane. I dont remember what brand intercooler but probably a VSPL (greddy).
So my final question for now would be (and I will look around to learn more of course) Do most of your 2.0L engines performing well at 7,000rpm produce about the same 350rwhp? I understand some of these cars are AWD. Any ideas how much of that power % is being eaten up? I'd like to make some comparisons for the sake of knowledge (for myself please )
Hope you dont mind all the questions and research here. If you do, sorry I dont mind researching but it seems like yall are wanting to chime in and type a bit which I love and would love to hear from you, personal experience and the like. I'd be more than happy to share mine.
Old Sep 22, 2013 | 07:27 PM
  #85
NOMIEZVR4's Avatar
bump....I wouldn't mind an explanation for the above either...
Old Sep 25, 2013 | 01:40 PM
  #86
E-SPEC INDUSTRIES's Avatar
Your questions are valid but very general. There are a ton of factors that affect VE in a motor but the "supporting mods" are what help the engine continue to make power by changing the factors that effect ve the most. Most importantly is to remove intake and exhaust restrictions. Before going into a motor, the parts bolted to it should support the power. Temp control and a good tune are the foundations to reliable set-ups.
Old Sep 25, 2013 | 02:04 PM
  #87
ReignMan24's Avatar
I think it's awesome that your trying to learn more and more about our cars. But I will tell you this, you're going to have your mind blown when you realize the true potential of these motors. The 4G63 is on a whole other level then all other 4bangers IMO.
Old Sep 25, 2013 | 04:42 PM
  #88
JaYr_EvO9's Avatar
nice job espec keep up the kick *** job
Old Sep 26, 2013 | 03:37 AM
  #89
soderdna's Avatar
It's good to be in this pursuit of knowledge. The SR20 is a pretty badass motor itself. I think the 2L turbo engine is probably the best design out there in terms of power, fuel efficiency and reliability. The numbers you can squeeze out of them is mind blowing. So many companies have or currently make one. Let's have a moment of silence for our 2L brothers haha
Introducing:
THE ALL MIGHTY!!!! 4G63
Toyota's 3S-GTE
Nissan' s SR20
Subaru's EJ20
Volkswagen's EA888
And let's not forget our Swedish brethren the SAAB built LNF
No replacement for displacement? Meh I disagree hahaha
Old Sep 26, 2013 | 08:29 AM
  #90
Darksun280's Avatar
We can generalize and agree that Heads and turbos make power and bottom ends have to hold it. If thats the case we should just argue who has the best stock flowing Head and sr20 or a 4g63.
i've had an Sr20 with a 280 cam and for some old tech it was pretty efficient.
