FP Red vs FP Black pump gas comparison
Old Feb 11, 2011 | 08:44 PM
jmcmill3's Avatar
Originally Posted by Evo3573
thanks for posting this up
+1
and +1 for the mods
Old Feb 11, 2011 | 09:27 PM
EVO8LTW's Avatar
Does it feel any different on the street? When I went from Red to Black, the turbo hit full boost at a very similar RPM, but the Black felt like it had to "wind up" a bit more when you punched it from a roll -- a difference in transient response.
Old Feb 12, 2011 | 04:20 AM
way2qik's Avatar
Originally Posted by dan08
Thats what I was thinking too. Ive made my mind up on the black.
Once the black gets turned up it will have a much harder top end hit than the red. So, you get that without sacrificing much at all downstairs.
Old Feb 12, 2011 | 05:03 AM
Mellon Racing's Avatar
on pump gas we consistently see similar numbers from the red to the black...octane/hotside seem to be the limiting factors. once you get better fuel we start to see the black stretch it's legs.
Old Feb 12, 2011 | 03:18 PM
420a-t's Avatar
So really other than transient response there is no reason to get a red over a black it looks like, correct?
Old Feb 12, 2011 | 04:16 PM
tscompusa2's Avatar
black is a bigger turbo in general. expect 150-200rpm laggier if both tune are optimized.
heres what i seen when i tested a car red vs black http://www.myevolution8.net/vrsf/keath2.jpg
my test isn't good either, because the previous tune didnt have optimum spoolup for the red therefore the test made it look like theres no lag when really there is lag..
you WILL feel the difference light to light red vs black.. the black is a bigger turbo so expect it to react like one.
Would i be wrong to say
a red is more like a 3076R
while a black is a 3582R
theres quite a difference once you raise the boost in a red vs black.
Old Feb 12, 2011 | 04:18 PM
ch1215g's Avatar
SUSPECTED SCAMMER
i was going to get the FP RED and i decided to get the FP BLACK i just finished the installation right now lol! NEED A TUNE!!!!
Old Feb 15, 2011 | 05:58 AM
keath's Avatar
same here
but all smiles after 5k...
Old Feb 16, 2011 | 06:40 PM
sparky's Avatar
Originally Posted by Mellon Tuning
on pump gas we consistently see similar numbers from the red to the black...octane/hotside seem to be the limiting factors....
Could you give us a bit more detail? Both turbos share the same turbine wheel and turbine housing. The Black is configured with a larger compressor wheel than the Red.
Is this truer on 91 octane than on 93? Or, are they about equal on 93 too?
Old Feb 17, 2011 | 01:02 PM
Mauricio Evo IV's Avatar
Very interisting information!!!!
One question for use FP Black:
If I only have FMIC AMS, HKS cams (272 ex/264 in), methanol (50/50), exhaust manifold, and 1,000 cc injectors, can I put the FP Black????? I now, I can!, but , how much power can I get with my mods??? Maybe I can change the 264 ex cam, but how much power can I get??
Ahh, internal motor with forged pistons and forged rods (standar 2.0).
Old Feb 17, 2011 | 02:37 PM
Fireant's Avatar
Im really suprised at this actually. Now i see no real reason to go red over black.
Old Feb 19, 2011 | 01:31 AM
if you could stuff a 42R compressor wheel into a housing it wouldn't help much because you're still limited to the tiny hotside that can only expel so much heat. heat is a killer on all normal pump gas 91-93 most commonly in the US. With e85 you can overcome the heat and keep knock away. that's when the black will begin to outshine the red.
Old Feb 21, 2011 | 06:57 AM
Broham's Avatar
i just found out e85 is near my house so bye bye pump. mellon, how bad is gas mileage on a black with e85. is it in the teens or can you get 20 mpg at least hghwy?
Old Feb 21, 2011 | 11:39 PM
Aby@MIL.SPEC's Avatar
how much of a difference was there in regards to city driving & transient boost???
pretty much when your getting on the fwy or accelerating a bit while ~3k in 4th gear while on city streets, etc...
i went from a black, tme, hta grn back to black in ~3 weeks time on a 2.3L e85 motor...
i liked the green, it's city driving is great, no surge in 5th gear on the fwy = awesome...just wished it had a bit more up top.....
i wish i knew the full facts on the differences between the grn, red & blk turbos...
im just trying to find the balance for me with regards to city life & wot performance.
interesting dyno results.
Old Feb 21, 2011 | 11:42 PM
forc3 f3d's Avatar
did you have cams with the green? im still back and forth on these few stock frame turbos...
