E85 Tune - no gain vs pump
Old Apr 6, 2011 | 10:27 PM
  #31
sparky's Avatar
Originally Posted by JohnBradley
Something big. 3.5" to 4" usually seems to work the best for most applications....
The 3.8" thick Garrett core is considered by many to be the best, most efficient core available. You can get this core in an ETS, Buschur Racing, or CBRD FMIC. An advantage with this core is no cutting necessary for proper fitment.
Personally, I'd like to try a 5", or 6" thick ETS IC. ETS has a new core design which they claim is extremely efficient. Of course I don.t mind trimming the bumper a bit and since I have a JDM front, then I have no bumper supports anyway.
But, I'd be willing to bet that if you were to take a survey regarding which IC is best for our Evo's the Garrett 3.8" core would win, hands down.
Old Apr 6, 2011 | 10:41 PM
  #32
Tonba's Avatar
Originally Posted by Stealthmatt
actually my bad i got clarification at 24 PSI it was seeing a 4PSI pressure drop at 27 PSI boost it was seeing a 7 PSI drop, so looks like the inter cooler can only handle about 20 PSI :P
Im having the same problem with my car. Needs a new cooler on it.. But I dont really have the $$$.
I can push 26psi, but the turbo seems to be struggling to push more. Running a 25psi actuator.
My intercooler definatly needs to be changed out. Need to decide on what cooler to use..
Plazmaman - 90mm/3.55" (API Core)
CBRD - 96mm/3.8" (Garrett Core)
ETS - 101mm/4" (?? Core)
ETS - 127mm/5" (?? Core)
Old Apr 6, 2011 | 11:32 PM
  #33
Stealthmatt's Avatar
Well I have a plazmaman intercooler - now i am not saying that there other bigger evo 9 intercoolers wouldn't be sufficient, However, I have the direct bolt on version and its suspose to support 700HP, i guess with less than 20 PSI boost lol
If the Garrett Core is what has been said to be the tried and tested and produce good results then Id be going for that.
Old Apr 7, 2011 | 05:46 AM
  #34
Benja's Avatar
Have you checked the WG pre-load though?
Old Apr 7, 2011 | 09:01 AM
  #35
ETS Michael's Avatar
ETS - 101mm/4" (ETS Core) ** We can also build the intercooler with a 3.8" or 4.5" garrett core
ETS - 127mm/5" (ETS Core)
Fixed. Thanks!
Michael
Old Apr 7, 2011 | 11:38 AM
  #36
JohnBradley's Avatar
I just made my most recent trip to the dyno on a 4" new style ETS core. Food for thought.
Old Apr 15, 2011 | 09:38 AM
  #37
coolguyuno1's Avatar
I made a lot more power on E-85 @31 psi vs my old 93 octane 25 psi tune but my intercooler has a 3.625" core.
supaduckie8113
10
Jan 29, 2012 03:20 PM
mt057
Sep 4, 2010 02:34 AM
EVOlutionary
E85 / Ethanol
23
Apr 18, 2009 12:13 AM
AcePitcher11
32
Dec 26, 2008 03:33 PM
razorlab
E85 / Ethanol
24
Nov 14, 2008 01:54 PM
