515 WTQ - Evo 9 2.4L E85
Old Apr 17, 2011 | 08:06 PM
RazorLab's Avatar
Fun little street brawler
2006 Evo 9 RS
Mods:
MAP 2.4L 9.7:1 Compression
FPGreen (OG version)
Cosworth M2 Mivec Cams
Turbo Back Exhaust
02 Housing
Samco IC couplers
GST / SE OMG cone filter
Bluemax 1450cc injectors
Walbro single pump
Perrin FMIC
GM 3 port using ECU PSI-target boost
Tephra V7
E85
30 psi peak to 17psi (motor needs a bigger turbo)
415 whp / 515 wtq (4th gear)
418 whp / 485 wtq (3rd gear)
Old Apr 17, 2011 | 08:41 PM
PeteyTurbo@KHC's Avatar
Thats awesome! Can't believe the OG green is out of steam.. Probably better off since the single pump probably is as well.. Good stuff.
Old Apr 17, 2011 | 08:44 PM
scheides's Avatar
EvoM Moderator
Haha! Street brawler ftw. Looks like epic fun!
Old Apr 17, 2011 | 08:59 PM
RazorLab's Avatar
Big motor to fill. The boost drops so much the IDC's are only at 56% max. IDC "curve" is basically flat at 56% from 5000 to 7500 rpm. haha
Old Apr 17, 2011 | 09:05 PM
s.e.a.n.'s Avatar
Crazy Tq. I find it weird that the green dies out so early on the graph.
Old Apr 17, 2011 | 09:13 PM
RazorLab's Avatar
It's a 2.4L and the OG Green isn't that much larger then a Evo 9 turbo.
For some reference, the highest OG Green on this dyno over the years has been 420whp, also on E85, but on a 2.0L
If I remember correctly, this very same car, with the stock 2.0L produced 415whp / 390wtq, the only difference between now and then is the 2.4L
Old Apr 17, 2011 | 09:22 PM
S13 Curtis's Avatar
Lots of torque, Im guessing it a 150mm rod since the torque is so high.
Old Apr 17, 2011 | 09:23 PM
Drifting Away's Avatar
good lord that tq is insane...
Old Apr 17, 2011 | 11:21 PM
Eisen7's Avatar
Haha... that's awesome BBK-B upgrade perhaps?
Old Apr 18, 2011 | 08:53 AM
whtrice's Avatar
Veteran: Air Force
Thanks Bryan for the tune!!!!!......response is amazing on this car. I just wanted to point out this is a MAP 2.4L shortblock. I will get a chance later to comment on this setup. I am looking to upgrade the turbo in the future but I will play with it like this for now. Turned out better then I thought it would!
100mm BTW.... edit...lol...that's what I get for reading ang typing too fast during my break....lol...150mm is correct!!
MAP 2.4L Stage II shortblock
9.7 : 1 Wiseco HD pistons
Balance Shft delete
MAP Ultimate duty 150mm I-Beam rods
MIVEC oil feed adaption
Thanks to Chris Carey and MAP for the great product and customer service.
Upgraded clutch to Exedy twin HD
HKS 4.11 final drive installed in trans during rebuild
Many thanks to Bryan for the tune and the crew @ GST Motorsports for the installation.
Old Apr 18, 2011 | 05:38 PM
whtrice's Avatar
Veteran: Air Force
updated.....
Old Apr 18, 2011 | 08:58 PM
NateSVT's Avatar
Wow, that torque is awesome!
Old Apr 19, 2011 | 03:16 PM
wilson1's Avatar
Man, this is crazy!
I want a ride!!
Old Apr 19, 2011 | 04:33 PM
boostedwrx's Avatar
[QUOTE=whtrice;9250734HKS 4.11 final drive installed in trans during rebuild
[/QUOTE]
I've been debating going 4.11 final drive on my 2.4 build (or just try taller tire if I want something different). How do you like the 4.11?
Old Apr 19, 2011 | 06:12 PM
tscompusa2's Avatar
this setup must feel very interesting for sure lol.. similar to being shot out of a cannon.
