Stock Block, FP Red, bolt ons Rnd 2
Old Jun 28, 2011 | 05:46 PM
Boost_Inspired's Avatar
damn awesome time bro , nice little sleeper you have there
Old Jun 28, 2011 | 06:16 PM
raasfaas's Avatar
Originally Posted by Steven
I'm building between 12-14 psi with the 2-step at 6K. The tires end up spinning whether I slip the clutch or dump it. Obviously, if I slip it, it takes a little longer until they break loose. Once the clutch is engaged. It destroys tires. Sometimes I gets sideways in 2nd on the street. I'm running about 25 psi in the tires. I think another set of wheels with Hoosiers are needed.
It sounds like you need a little more finesse off the line, maybe try a little lower tire pressure with less boost (its really about trying different combinations)
On my street tires (235/40/18 Federal RS-R's) I used to pull low 1.7's
Thanks man
Old Jun 28, 2011 | 06:37 PM
LGshow19's Avatar
Thanks man
So what is your 0-60ft now?
edit: Just read the original post again and found the answer ahaha
Old Jun 28, 2011 | 07:11 PM
Mikey@Spec-Ops's Avatar
Congrats Brother. You have a great tuner man
Mikey
Old Jun 28, 2011 | 07:17 PM
596736's Avatar
Nice man. Any significant weight reduction done? Is this on IX gearing?
Old Jun 28, 2011 | 07:23 PM
noob12's Avatar
Can EVOs really be sleepers?
Very nice on the stock block.
Old Jun 29, 2011 | 05:44 AM
raasfaas's Avatar
Yup, I was pulling consistent low 1.6's...with a best of 1.55
Old Jun 29, 2011 | 05:48 AM
raasfaas's Avatar
Mikey
Thanks man..you do know this was self-tuned right
Nope, absolutely no weight reduction...full weight MR (including spare tire and jack)
And yes, this was on the OEM 6spd box.
Thanks man, appreciate it.
Old Jun 29, 2011 | 06:43 AM
s.e.a.n.'s Avatar
Congrats on the New PB!
The OEM 6Spd is holding up good I'm surprised you didn't have to shift into 5th.
Whats the specs on the wheels? Did you use spacers? Are you using the stock brakes up front?
Old Jun 29, 2011 | 07:28 AM
No, I'm an idiot and saw self tuned after I posted it... I thought at first Aaron remote tuned you. My bad, but looks great!
Mikey
Old Jun 29, 2011 | 07:33 AM
High_PSI's Avatar
REALLY pushing that stock block.
Old Jun 29, 2011 | 07:34 AM
High_PSI's Avatar
Are the S2's drop in or do you need springs and retainers?
Old Jun 29, 2011 | 07:35 AM
^ I ran 540whp for 1.5 years and didn't have a single problem
I would keep the stock motor as long as possible. I think a Black at 550whp would be an awesome stock motor setup as long as you keep tq below 425.
Mikey
Old Jun 29, 2011 | 07:42 AM
AngryEvo8's Avatar
Good power and times! Hope ur hit your 10sec goal soon! Im in the same boat as you
Old Jun 29, 2011 | 07:48 AM
The IXs tend to be okay to 7-7.5k but every car is different. I always reccommend springs/retainers. I personally think the $300 investment is well worth not running the chance of dropping a valve and blowing a motor.
Mikey
