Stock Block, FP Red, bolt ons Rnd 2
Old Jun 29, 2011 | 08:11 AM
  #31
06MREvo's Avatar
Originally Posted by Mikey@Spec-Ops
The IXs tend to be okay to 7-7.5k but every car is different. I always reccommend springs/retainers. I personally think the $300 investment is well worth not running the chance of dropping a valve and blowing a motor.
Mikey
^^What Mikey said, If your doing cams you might as well do springs & retainers too...I threw a set of Supertech Duals in when we did my S2s...
Old Jun 29, 2011 | 08:17 AM
  #32
06MREvo's Avatar
Originally Posted by raasfaas
Nope, absolutely no weight reduction...full weight MR (including spare tire and jack)
And yes, this was on the OEM 6spd box.
Wait....You ran these times with the 6 spd??? Impressive sir!! Obviously you are shifting to 5th because if you tried to stay through the traps in 4th & run the MPH you did you would be over 9000rpms, haha....
What are your shift points? I am very interested now...I won't have the funds anytime soon for the built 5 spd & t-case I want, so I am gonna have to push the 6 spd till its donzo...
Old Jun 29, 2011 | 09:21 AM
  #33
Guerillah's Avatar
I watched the video and he stayed in 4th. The MR and IX 5 speed have almost the same mph in 4th gear (within 1mph if i remember right). Evo 8 4th would help tremendously.
Old Jun 29, 2011 | 09:23 AM
  #34
raasfaas's Avatar
Originally Posted by s.e.a.n.
Congrats on the New PB!
The OEM 6Spd is holding up good I'm surprised you didn't have to shift into 5th.
Whats the specs on the wheels? Did you use spacers? Are you using the stock brakes up front?
Thanks Sean...to be honest I don't know the exact specs on the wheels but I'll find out and let you know, but I did have to use spacers up front though to clear the brembos (which answers your next question...stock brakes)
I was considering shifting to 5th, but since these tires are taller than my 18" street setup I didn't have to take 4th that far (8200rpm according to my logs)
Old Jun 29, 2011 | 09:36 AM
  #35
raasfaas's Avatar
No, I'm an idiot and saw self tuned after I posted it... I thought at first Aaron remote tuned you. My bad, but looks great!
Mikey
NP man...Aaron really is the best though, he and I have been in contact on numerous occasions offering advice and pointing me in the right direction.
Originally Posted by High_PSI
REALLY pushing that stock block.
Are the S2's drop in or do you need springs and retainers?
That was the main reason I didn't go any further on the dyno, I didn't want to push it anymore (I knew that where I had it was good enough power to take the 11 sec trophy, but was hoping that I would have the chance to go for the 10pass)
And I know there's a lot more left in it as this was only @ 30psi.
I would recommend doing the springs and retainers just as added insurance...I originally had the S2's on the stock valvetrain but when I went up in the powerband I experience valvefloat...so I dropped in a set of supertech singles and have been good ever since.
Originally Posted by AngryEvo8
Good power and times! Hope ur hit your 10sec goal soon! Im in the same boat as you
Thanks man, I'm sure I'll get it the next time around
Mikey
Very true, it's not worth the risk.
Old Jun 29, 2011 | 09:46 AM
  #36
raasfaas's Avatar
Yessir, the stock 6spd...remember that I'm on much taller tires so you have to take that into account. I crossed the light at the top of 4th at I believe 8200rpm.
1st>2nd I shift early like 7300rpm, 2>3>4 I shift at 8000rpm, and 4th I just hold out until I cross the line.
Yea I definitely would benefit from going with a 5spd conversion...who knows maybe that will be in the near future.
Old Jun 29, 2011 | 11:02 AM
  #37
06MREvo's Avatar
I know this...Whenever I do my 5 spd swap, it will be a IX 5 spd with an VIII 3rd & 4th gear...
Old Jun 29, 2011 | 11:11 AM
  #38
06MREvo's Avatar
Thats crazy the tire size made that much of a difference, damn...Makes me want to get a wheel/tire setup like yours and see what my car will do...What is the exact tire size you are running?? I am running 255/40/17 Hankook street tires & I have no problem cutting 1.6x 60 fts on them...But if I were to try and stay in 4th and have an 8250 rev limiter I would only trap 120mph if I'm lucky...you trapping over 8 mph more then that at only 8200 is sickkk....
Old Jun 29, 2011 | 11:53 AM
  #39
Guerillah's Avatar
You would need a 255/45/17 to = the same size tires as him. Although his probably grow more when hot so who knows what size they really are.
Old Jun 29, 2011 | 12:06 PM
  #40
raasfaas's Avatar
They are Hoosier Quick Time Pros 26*9.5*16
Old Jun 29, 2011 | 12:11 PM
  #41
raasfaas's Avatar
Yea this definitely isn't an apples to apples comparison...plus the fact that our track isn't a fully prepped track either (trackbite etc.)
Old Jun 29, 2011 | 12:13 PM
  #42
High_PSI's Avatar
OH Ok you have METH, I have just pump gas I missed that part. I made 454WHP and 400 FP's with my 84MM FP Red and S1 cams. at about 29PSI falling to 27PSI. I bet if I got S2's I could get another 20WHP up top.
Old Jun 29, 2011 | 12:24 PM
  #43
raasfaas's Avatar
Yea I have meth but do remember this isn't my regular street tune...this is my strip tune...which is a 50/50 mix of Q16/90oct pump gas without the meth.
On the rd I usually run a little conservative...26psi with the meth (443/345)
Yea I'm sure the S2 would give you a pretty decent gain up top (and not lose much down low either )
Old Jun 29, 2011 | 12:35 PM
  #44
06MREvo's Avatar
Yeah, a 45 side wall would throw off the speedo some, that is why I went with a 255/40, closer to stock size...
Good to know, thanks man!
Old Jun 29, 2011 | 01:22 PM
  #45
06MREvo's Avatar
Also, are you using launch maps & if so what psi are you launching at??
