BBK Full, e85, SD, Stock Block, 500hp/450tq
http://www.youtube.com/watch?v=pePwP1W80TI&hd=1
Performance:
DB Tuned by Shane on e85
Speed Density
CBRD BBK Full Ported Turbo
FIC 1250cc Injectors
GSC S1 Cams
MIL.SPEC TB Seals
MAP 25psi Actuator
MAP Custom Air Intake with Spectre Filter
MAP Cam Sensor Shield
MAP Custom UICP
MAP Tubular Long Runner Exhaust Mainifold
MAP o2 Housing
ETS 3.5” IC
Muse LICP
Walbro In-Tank 255lph Fuel Pump
Kenne Bell 40amp BAP
Turbosmart 50mm Race Port BOV
Hallman Pro MBC
Grimmspeed EBC
FP Exhaust Manifold Stud & Nut Kit
DC Sports Catless Downpipe
GReddy Evo2 Catback
Zaklee Clear Cam Cover
Suspension:
Robispec KW V3 Clubsports
Robispec Rear Sway Bar
Whiteline Front Roll Center Kit
Whiteline Rear Trailing Arm Bushings
Whiteline Rear Bump Steer Kit
Vorshlag High Castor Front Camber Plates
Stoppage:
StopTech Slotted Rotors, front and rear
Hawk HPS Front Pads
StopTech Street Rear Pads
StopTech Stainless Braided Lines
Motul Fluid
Trans:
5 Speed RS Swap with all new parts
Spec Stage 3+ Clutch with Billet Flywheel
Speed Source Shifter Base and Cable Bushings
Wheels\Tires:
Summer:
Enkei RPF1: 17x9.5 +18 front, +38 rear
Falken Azenis RT-615k 255/40/17
Drop Engineering open-ended Lugs
Winter:
Stock MR BBS
225/45/17 Semperit Winter Sports
Interior:
Gruppe pod
Prosport HALO Gauges-- Wideband, Oil Pressure, Boost
Trustz Gauge Overlays
LED bulbs
Alpine CDA-105 Headunit
Boston Acoustics SC65 Speakers
Exterior:
Evo 7 Tail Lights
eBay Poly Lip
Performance:
Speed Density
GSC S1 Cams
MIL.SPEC TB Seals
MAP 25psi Actuator
MAP Custom UICP
MAP o2 Housing
ETS 3.5” IC
Muse LICP
Hallman Pro MBC
Grimmspeed EBC
GReddy Evo2 Catback
Suspension:
Stoppage:
Hawk HPS Front Pads
Motul Fluid
Trans:
Wheels\Tires:
Summer:
Winter:
Stock MR BBS
Interior:
Gruppe pod
LED bulbs
Exterior:
Evo 7 Tail Lights
eBay Poly Lip
I totally agree, the cost to buy a new clean block when you fling a rod through the side makes it silly to push that kind of power.
I do it
1. Because it can be done and done safely if you have a good tune and a good combo.
2. If you're not ready to do a build.
3. If you have a perfectly running motor, why not run it? How do you know he wants a 63 block I. The future anyways?
Nice numbers man, what's the plan for the future?
