Fuel Map Tuning Help
Old Jan 18, 2012 | 06:53 AM
tscompusa's Avatar
Originally Posted by djchopps0013
Just a attempt to get a big time tuners input!
I realized it after I posted it.
If I leave it plugged in and just bypass vacuum line is there a need to edit periphery bit? Or am I better off pulling and editing periphery? Does the periphery bit only affect FPS?
as long as its plugged in and receiving a signal it wont throw a cel.
Old Jan 18, 2012 | 11:09 AM
djchopps0013's Avatar
Ok fixed vacuum line from FPR to mani, ran two 3rd gear WOT runs and AFR still super lean up top. Any other ideas?
Just to verify I believe I disabled lean spool correctly, maybe someone with more knowledge could verify. Tables added
<table name="Lean Spool Start RPM" category="Fuel Lean Spool" address="1280" type="1D" level="1" scaling="RPMStatLimit"/>
<table name="Lean Spool Stop RPM" category="Fuel Lean Spool" address="1284" type="1D" level="1" scaling="RPMStatLimit"/>
Start and stop RPM values set to 1500 and 1500
9* at 6500 19PSI at 6500
Found a post where people were experiencing similar issues and resolved replacing fuel pump relay. Will give that try as well.
Attached Thumbnails Fuel Map Tuning Help-leans.png   Fuel Map Tuning Help-graph.png
Old Jan 18, 2012 | 11:46 AM
211Ratsbud's Avatar
Def something in the system that tells the fuel pump to go full bore. That small line i mentioned is common especially with the age of our cars and crappy rubber vac lines oe. Check or test the relays, your on the right path.
Old Jan 18, 2012 | 01:39 PM
Can anyone tell me which is the Fuel pump relay for EVO 8 MR? It just shows pictures on cover. I found the below diagram. Its a lie! Its says B 128. I only found 2 relays on opposite side. Just not sure what is what.
4b11slayer
Dec 5, 2016 06:37 AM
Dr. Jekyll
Apr 1, 2016 08:42 AM
WRC-LVR
Oct 14, 2015 04:12 PM
07EvoIX
Oct 28, 2012 12:49 PM
Appauldd
Jul 4, 2009 07:42 AM
