703whp 3586 Old School 2.4
Old Feb 25, 2013 | 07:04 PM
  #61
JohnBradley's Avatar
Normally on 92 I max out at 28psi and 10-11* at 8k...thats on a good breathing setup. On 93 I can usually push another 2-3psi and at least 11-12* and sometimes more all at the same time. What cast exhaust manifold?
Old Feb 25, 2013 | 07:21 PM
  #62
Blue91lx's Avatar
I've been since checking out your 3586 92 threads and they all look incredible. That's crazy you notice that much of a difference between 92 and 93! it's almost like the difference between 91 and 92.
I have a HAFE cast kit that Mr. Brown is working his magic on for me.
The castings are all knocked down on the head and the bowls have some nice work done to them, so it should respond a bit better to the S3s.
Old Feb 26, 2013 | 03:52 PM
  #63
It helps I am pretty good at saving and cataloging all the tunes I do and logs 91 octane is not all the same though. ACN (Arizona, California, Nevada) 91 is like our 89 here. Midwest 91 like Kansas is like our 92.
Aaron
Old Feb 26, 2013 | 09:37 PM
  #64
500hp_beauty's Avatar
very impressive numbers
Old Feb 27, 2013 | 01:51 PM
  #65
batty200's Avatar
So was this a HTA 86 the whole time or a 6235?
Old Feb 27, 2013 | 02:59 PM
  #66
First it was a FS635 then it went to the 3586 as far as we know, it was used but looks right. Definitely 2 different turbos.
Old Feb 27, 2013 | 03:34 PM
  #67
tscompusa's Avatar
Adam you need reading glasses!
I am one to talk though. i cant see without correction unless I'm 1mm from the screen breaking my neck/back.
Old Feb 27, 2013 | 06:39 PM
  #68
mitsubeastlee's Avatar
**** look beast. fp black and hta 3586 by far my favorite 2 turbos currently
Old Mar 11, 2013 | 10:02 PM
  #69
anthonyrb98's Avatar
on 92, the car pushed around 580+whp on a dynojet.
Old Mar 14, 2013 | 08:35 PM
  #70
batty200's Avatar
I read both threads and at one point it was an unknown. Then I never saw a definite change of Turbo. The first post in this thread says 6235. So it was confusing.
Old Mar 14, 2013 | 10:35 PM
  #71
Blue91lx's Avatar
Very good to know, thanks for the response. Speaking of response, how does it feel on the street?
Old Mar 18, 2013 | 10:02 AM
  #72
the 2.4 definitely helps on the low end. as far as spool goes, the 2.4 also helps the 86 come to life. boost comes on pretty quick for a turbo this size.
Old Apr 24, 2013 | 12:59 PM
  #73
old school
Old Apr 24, 2013 | 01:24 PM
  #74
EvoJoeIX's Avatar
How much spool will you lose by switching from s2 to s3?
Im between the s2 and s3 cam for my 2.3 w/ hta86 build right now. Im loving where you hit full boost on the s2
Old Apr 24, 2013 | 03:34 PM
  #75
you'll probably lose a few hundred. i was told that gsc's newest cams are better. best of both worlds - fast spool and higher top end power - spool i'm told is unaffected between the s2 and the newest style gsc cams.
