evo 8 tuned by tscompusa
Old Apr 9, 2012 | 12:50 PM
TigOLDBiTTies's Avatar
Originally Posted by tscompusa
the afr is reading something else in your dyno sheet. ill check the logs you sent me.. also theres alittle more in this car yet its on the rich side.
but you're welcome.. and that turbo looks crazy.. looks like fuel hose clamp or worm clamp got in there and the turbo didnt want to stop spinning and completely ate it up.
the afr was all screwy from the original dyno run, the final tune was just fine but when you combine the two it gets all messed up.
heres the last run alone.
Old Apr 9, 2012 | 05:01 PM
tscompusa's Avatar
The load was in the wideband column on the old log.. happens when you change the listing order in evoscan without closing and reopening it. that's why it was reading crazy like that.
here is the 2 logs you sent me to share on my vd:
we could prob brush the afr a bit downlow to make a 1:1 hp/tq ratio if you want.
Old Apr 9, 2012 | 05:03 PM
tscompusa's Avatar
Originally Posted by SPATT
It didnt want to stop but it looks like it finally gave in..
so yours ingested a worm clamp as well and looked the same as his? its hard to see inside in the pics you posted.
Old Apr 9, 2012 | 05:41 PM
Boostevo58's Avatar
I hope I can get numbers like that. Sucks that you had to deal with that stuff after buying a evo. Now you have a pretty fast street car tho.
Old Apr 9, 2012 | 06:47 PM
ya shes got some ***** now for sure.
why is the hp different in your graph? weird
Old Apr 9, 2012 | 06:50 PM
tscompusa's Avatar
you have to update your virtual dyno to the newest version http://www.bradbarnhill.com/projects/VirtualDyno/
High_PSI
119
Oct 4, 2016 08:20 AM
tscompusa
Sep 2, 2013 07:41 AM
turboimpala
Apr 10, 2013 12:36 PM
dingus
Dec 2, 2011 10:55 PM
Stradag
Aug 20, 2011 11:39 AM
