Stock block/head/turbo 8- 440/439@32 psi
i guess ill be the first to say that's not possible with hks 272 on a stock 8 turbo.. 10.5 hotside or not.
can you email me your log so i can put it into virtual dyno and play with it? something looks way off with that graph..
i bet with smoothing 10 it drops under 400whp in vd. email me log with tps, rpm, tscompusa@gmail.com -- unless you don't care about advertising highly inflated numbers.. then i guess don't.
Hallman mbc that is about 1 turn from bottomed out is how. I dont expect the turbo to last long at this level... but at 150 bucks, who cares lol. I dont see why this is so hard for some of you to believe. Isnt the record for an 8 turbo over 460whp?
just email me your tire diameter, the vehicles weight with you in it, gearbox data / car model etc when you send me the log. also make sure the left data on the log remains in tact ( LogID LogEntryDate LogEntryTime LogEntrySeconds)
Ya i will include all that. I really dont want to mislead anyone here. I have never had the valvecover off the car to check what cams it has for sure, but i assumed by how they sounded and the mild topend they were the hks cams. If it becomes a big deal i will pull the cover and look. I am sure it has the bone stock 10.5 hotside 8 turbo though and will get pics of everything if need be.
Well the number as i see it, is high mainly due to a big spike and the afr being about 12.5 at that point. The rest of the powerband looks fairly normal as far as i can tell and without the spike would probably be in the 390 to 400 whp range. Does this seem more accurate for everyone?
i would say its definitely possible to make those numbers if the car is in great running shape and is a freak. I trapped 121 with hks280 on the 10.5 8 turbo with a stock o2 housing and a weight of 3250 with me inside. To be honest i shifted slow so that could be higher so i would say an aggressively modded car could make that power because mine is nothing special.
