My Evo 7 lost power !! help
Old Apr 21, 2012 | 07:45 PM
eazlan's Avatar
Hi Mate, Please advise me,
Yesterday had a dyno Dynamic test .
My Car is Evo7
Mod with : Tomei Arms M7960,Cam Brian Crower 272 Stage 2, Fuel Pump Walbro 255, Fule Regulato, Stock Ecu
Max result recorded 204 HP...
Checked not leak at hose by the leak tester..
Any sugestion what should I do ..
Old Aug 17, 2012 | 08:42 AM
HsamehH's Avatar
hard to tell without log,for exampe boost/timing/afr,you also need to leak test the piping,and check for exhaust leak,you have to provide information,also i cant see anything from the graph you uploaded.
Old Aug 17, 2012 | 10:26 AM
BlackEvo_5's Avatar
Need to retune the ecu, with ARMS the load range in the map is way off from where the standard turbo's load range was.
Retune the ecu, afr, timing etc.
Old Nov 8, 2012 | 03:27 PM
burgers22's Avatar
Possibly the waste gate stuck open. Can you see what boost it is running?
Old Nov 8, 2012 | 06:17 PM
HsamehH's Avatar
what's the old dyno numbers ?
Jovan Caro
Apr 19, 2017 11:40 AM
gsteensland
10
Jul 7, 2016 08:23 PM
speifer
Apr 28, 2010 11:30 AM
freakitgood
Mar 19, 2009 12:13 AM
Turbo-Evo2346
May 11, 2006 12:19 PM
