tscomptuned BBK Full: Virtual Dyno vs Dynojet
Old May 4, 2012 | 10:10 AM
vmrevo9's Avatar
Veteran: Air Force
good comparo Blitz! nice numbers on pump with the Full. hopefully i'll get mine there soon.
Old May 4, 2012 | 12:11 PM
Blitz's Avatar
You mean you ran 11.79 with less?
Old May 4, 2012 | 03:43 PM
vmrevo9's Avatar
Veteran: Air Force
i VD chart shows 401hp/369 tq @26psi
this was with slight knock counts throughout the run.
and it slightly peaked at 26psi at the track
Old May 5, 2012 | 12:57 AM
Blitz's Avatar
Wow nice driving!
Old May 5, 2012 | 01:58 AM
vmrevo9's Avatar
Veteran: Air Force
well my new tires made a big difference. they are nothing special they are just regular street tires but they provided much improved grip over my old worn out tires
hopefully i can get kicked off the track next time out
Old May 5, 2012 | 04:08 AM
mxguy1286's Avatar
Originally Posted by 5LEEPERISAH23I
VD FTW! all the VD hater argue with that bahaha. if u have the correct weight n are on a flat road its going to be dead on end of story
Oh yeah cause its always 100% dead on all the time.... Glad to see you didnt see it in person when it was no where near close before.....Its a hit or miss program. Some cars it may be close others well its just not even.
O.p. Glad to see you made the numbers you expected. Always a wieght lifted off the shoulders when it makes what you hoped for!
Old May 5, 2012 | 03:39 PM
tscompusa's Avatar
i did try to match the numbers i received later and posted the info here: https://www.evolutionm.net/forums/10...-post1382.html
i dont really agree its a hit or miss program based on what ive been seeing when its used properly on my personal evo.. after i took my car on route 30 and did pulls my numbers have drastically gotten lower.. if i had done this from the beginning i wouldn't have been that far off at all on my numbers.
its safe to say you can easily inflate the numbers if you aren't careful though or not paying attention or just not using a smooth or flat enough road in general. that doesnt make it a hit or miss program in my book though.
not to mention 540whp i have logs when my car was at the track trapping 131's and 540 is right on target for that trap speed and my race weight. (3350lbs)
Old May 5, 2012 | 05:50 PM
Boltz.'s Avatar
FCOTM Winner
Originally Posted by bbarnhill
You have really lost your mind haven't you? Its only good for peak power? If anything a dyno is NOT for showing this. It does show the dips in power where it should. So I have to disagree with pretty much everything you said. I think you have had a bad experience with 'Virtual Dynos' but not Virtual Dyno. You used the one built into evoscan, which has been known to be crap. Oh but it should get better since he decompiled my app and stole my code for the new version.
Easy,
Not trying to knock your product with my previous statement. I am spoiled and get to spend a lot of time on the dyno so my opinions are biased, a virtual dyno just isn't the same. It serves its place in the market given it is a infinitely cheaper option than investing in a dyno. Kudos for making a good product.
Old May 6, 2012 | 01:50 AM
nobudgettuning's Avatar
good job Tom
Old Jul 18, 2012 | 12:50 PM
Levar's Avatar
Veteran: Army
You made more power on the BBK Full on 93-octane than I did with the EF4 on 91-octane.
Old Jul 20, 2012 | 05:52 PM
boostedwrx's Avatar
Looks good - the bbk is a good effin pump gas turbo. Nice comparo too
Old Apr 16, 2013 | 04:54 PM
tscompusa's Avatar
just throwing this out there so others can see.
This is the exact same VD graph posted in the first post but with higher smoothing. vd reads lower when smoothed high with a legit graph.
Old Apr 16, 2013 | 06:02 PM
Silvermike's Avatar
the peak tq always takes a hit in the VD cuz of the smoothing factor applied....
what it needs is 2 factors.... one for pre-spool, one for full boost... and an adjustable cross over point for these values to account for different turbos.
Old Apr 17, 2013 | 11:00 AM
5LEEPERISAH23I's Avatar
My favorite part about this post is you dont see any of the VD Haters posting fighting about how that number is off.
VD has been dead on to me "i think" My VD numbers always match my 1/4 Traps they should go.
550whp i went 129-130 mph
630whp i went 133.6 mph
that is pretty much dead on full weight and street tires "not to mention shifting in 5th" i think that hurts your MPH some say it doesnt, good thing is we will find out in less then month of that is true or not. Just put 4.11's in there with the same setup as the 133.6mph so we will we if i gain MPH.
Old Apr 18, 2013 | 08:53 AM
hachansoo0413's Avatar
great comparison!!!!
