First Virtual Dyno Log? Need comments
Old Jun 27, 2012 | 04:08 PM
ReignMan24's Avatar
alrite guys, i have no idea if i even did this rite at all, im just lookin for comments on y the number is a little on the high side for wat is dne to my car. car is 05 evo 8 rs, mods...agp 3.5 IC, agp licp, stock intake with open cone filter, stock uicp, megan racing tbe with test pipes, aem truboost set to 60% duty cycle(looks like its holdin 21-22 to redline, now the car is completely untuned, i have a tune comin up this weekend, still have to put my injectors, fuel pump, new spark plug wires and new spark plugs in, neways, main question is the VD way off or do these cars just react really well to mods even untuned? i was extremely surprised and actually expecting less then stock numbers from bein untuned....ne comment is welcome, just tryin to get sum answers
ps. check out attachment, cant figure out how to just upload image
Old Jun 27, 2012 | 04:52 PM
tscompusa's Avatar
looks goofy to me.. but that was fast lol. i just got done emailing you the evoscan registration and you went to work that quick
on that version virtual dyno you're using go to properties check smooth time & rpm and close it and reopen it. then give it about a smoothing 5 id say or maybe 3 and retry..
or send the log to tom@tscomptuned.net and ill post what it should be for you.
Old Jun 27, 2012 | 04:55 PM
ReignMan24's Avatar
will do lol, we still good for saturday man? lol got parts to install if were still good
Old Jun 27, 2012 | 05:06 PM
tscompusa's Avatar
not 100% certain on what you're referring to. email me and ask for more information. also send me the log so i can post it in here for you.
edit: just read your pm.. yes Saturday is good.
Old Jun 27, 2012 | 06:01 PM
ReignMan24's Avatar
Tom, heres smoothing of 3 and 5, ill still send u the log to see if you get sumthing different, thanks again
Attached Thumbnails First Virtual Dyno Log? Need comments-smoothing-5.png   First Virtual Dyno Log? Need comments-smoothing-3.png
Old Jun 27, 2012 | 06:07 PM
tscompusa's Avatar
ok go do the pull again and this time start the logger about 20 seconds before you do the pull.
your computer is chopping the spoolup curve off so its making it look goofy.
also make sure its on the interstate or somewhere REALLY smooth, or it will inflate the numbers.
Old Jun 27, 2012 | 11:57 PM
tscompusa's Avatar
ok just now figured out what email was yours the numbers are high because you're running more boost and the timing is pretty high. it peaks at 15* uptop.
avoid doing anymore pulls, because its knocking uptop from trying to run to much timing.
Polov93
Jul 22, 2016 06:17 PM
Fortune-Auto
Jun 5, 2013 08:20 PM
WTXevolution
23
Jan 4, 2013 02:56 PM
Mr. Move
May 14, 2012 06:38 PM
REVOlution86
Jan 14, 2009 10:15 AM
