Evo 8 GT30r dyno results
Old Sep 11, 2012 | 08:50 PM
YogSaahoth's Avatar
Veteran: Army
really dies up top. Even my green with hks 272 holds 300tq at 7k. Historically, ATP bolt on turbos have never done well on our cars, esp the 3071. My full bolt on and cam stock 8 turbo made the same power at 25psi, obviously with much better spool. The stock o2 is hurting spool and overall flow, but I'd still ditch that turbo...won't make much more than a stock turbo but will be much more laggy
Old Sep 11, 2012 | 09:19 PM
castellon1's Avatar
Thanks for the info. my understanding was that the stock evo 8 turbo was very restricted over 21 psi. which is why i installed this turbo as opposed to selling it. guess ill port the manifold and get an aftermarket o2 housing or dump. should keep me content untill i do a full rebuild and upgrade to a bigger turbo
Youknow's Avatar
looks all right to me .
Old Sep 12, 2012 | 08:12 AM
sliqdaddy91's Avatar
extremely low I feel like you should be around 390-400 and then with the 02+ manifold maybe 430ish but that's just my two cents
Old Sep 12, 2012 | 09:53 AM
Graphic's Avatar
What tuners do most people recommend in his area?
Old Sep 12, 2012 | 11:22 AM
castellon1's Avatar
I've heard good things about ISP in maryland. Going to check them out . AMS is good too. Hopefully I can get more power out of my set up
Old Sep 12, 2012 | 11:41 AM
Boosted Tuning's Avatar
Originally Posted by MDA89
You do realize this turbo is smaller than a stock 9 turbo correct???? It's litterally marginally bigger than your stock turbo.......my correction not smaller but arguably the same size as an evo 9 turbo...
The flow numbers
Stock 9-------------42-43 lb./min.
Gt30----------------50-52 lb./min.
Old Sep 12, 2012 | 12:51 PM
deylag's Avatar
Those are good numbers for the mods and the fuel you are using. Thanks for sharing your turbo results.
Old Sep 12, 2012 | 04:24 PM
ZanarkO's Avatar
thats low i think ppl r forgetting hes using s1 cams.... it should be around 380whp on a dynojet
Old Sep 12, 2012 | 04:30 PM
EdSales's Avatar
Originally Posted by castellon1
Was tuned at Moore auto in Fairfax VA
I was trying to choose between Moore Automotive and Agile. I think I am going to drive the extra miles to Maryland now,
Old Sep 12, 2012 | 05:21 PM
Noob Sauce's Avatar
It's just funny how people aren't comparing the before and after instead are comparing dyno numbers from different place and time...
Old Sep 12, 2012 | 05:35 PM
castellon1's Avatar
It started at 250-260 HP untuned. I was wondering if there was something fhat could be limiting me as far as getting to or past 400
Old Sep 12, 2012 | 05:43 PM
castellon1's Avatar
Moore did a good job. I just didn't think havubg the stock o2 housing would hurt me so much
Old Sep 12, 2012 | 07:06 PM
Noob Sauce's Avatar
O2 housing and stock manifold is holding you back...
Old Sep 12, 2012 | 09:08 PM
Moore Auto's Avatar
Oh wow, where do I begin? First of all, this is a high mileage '03 stock bottom end. I was being a little conservative to help it keep living. The ATP bolt-on GT's were never all that good, and laggy to boot. Now, put a stock, horribly restricted O2 housing on it so it can't breathe out very well, AND with S1's (yes, they're better than stock, but still not that great on the top end) and what do you get? Something that dies on the top end. You guys act like he should be making 400+ whp on a choked engine with the little bit of mods he has.
And btw, our DynoJet reads lower than a local "heartbreaker" Dyno Dynamics and Mustang Dyno. And I don't trust AMS's dyno as far as I could throw it. Everyone that's been on our dyno after there's, said their dyno reads around 40-50whp higher. So don't let inflated numbers fool you.
~Chris@MooreAutomotive
