Stock block, head, 9.8 turbo Self Tuned V7
Old Jan 6, 2013 | 01:46 PM
ReaperX's Avatar
Lightly Modded Stock 9.8 turbo Self Tuned V7 294/286 VD
Finished my tune today, 294/286. Previous results posted were 283/280. I have tapped out my almost 100k mile (will turn it tomorrow) baby. Increases in timing did not make any gains from where it sits right now. Leaning out induced knock in the upper rpm's. Quick 25psi spike and tapers to 22 at 7k.
I will be getting it on a dynojet soon to see what the SAE corrected numbers are so I can begin NASA Time Trials this year. Then it will be time for e-85.
Power Mods are as follows:
Perrin filter w/ maf adapter
Megan 3" dp, tp, cat-back
Grimmspeed 3-port
Wally 255
Stock block
Stock head
Stock 9.8 housing turbo
Stock injectors
No porting of anything at all
Thank you for your time.
Attached Thumbnails Stock block, head, 9.8 turbo Self Tuned V7-final-test-38-map.png
Old Jan 6, 2013 | 03:16 PM
aggieEVO's Avatar
Very nice. Good to see numbers on a car with minimal mods. I'm hoping to install a 3 port pretty soon after I get the car together and make the most out of each mod.
Best of luck!
Old Jan 6, 2013 | 06:40 PM
ReaperX's Avatar
Thanks. Ya it is tough to find results for very lightly modded VIII's or IX's anymore.
Old Jan 7, 2013 | 12:05 AM
Socal's Avatar
Nicely done
Old Jan 7, 2013 | 12:59 PM
Boosted Tuning's Avatar
Update your Virtual dyno, its super old.
Also, in this weather with 93oct, you should be able to hit about/least 320hp.
Old Jan 7, 2013 | 04:45 PM
ReaperX's Avatar
I have been lazy updating that apparently lol. I have no doubt it will get there. I have finally been able to get repeatable results after switching to V7 and learning the 3-port. Next step is midrange timing, currently only running 2* from peak boost to 5300. The it will be to lean it out up top, currently it tapers from 11.3 to 11 @ 5500, then to 10.6 by 7k. I am hoping to do that this weekend and post my final results.
I was just so happy I felt I needed to share .
Old Jan 7, 2013 | 04:48 PM
itsmrrizz2you's Avatar
Good job on the self tune. Keep tweeting it for some extra power
Old Jan 7, 2013 | 06:17 PM
Stay outta the 10s for afr.
Old Jan 7, 2013 | 06:21 PM
ReaperX's Avatar
Absolutely. End goal is 11.1 up top for when I go to the track (boost lowered a bit as well), and 11.3 for the street.
Question for you, is it possible to surge a stock turbo on my setup? I am getting some flutter right before peak boost, but thinking it is the wastegate since I haven't put anymore preload into it than stock.
Old Jan 20, 2013 | 06:40 PM
ReaperX's Avatar
Updated first post with final numbers.
Old Jan 20, 2013 | 06:47 PM
DrG46and2's Avatar
very nice numbers good job!!! smooth graph
Old Jan 20, 2013 | 06:54 PM
ReaperX's Avatar
Thank you man!
Old Jan 22, 2013 | 10:09 AM
BEKevo's Avatar
Nice job man
Old Jan 26, 2013 | 02:23 PM
ReaperX's Avatar
Thank you!
tscompusa
Jan 26, 2015 07:21 AM
Spooln-Evo
Nov 17, 2013 04:28 PM
Endless AWD
Oct 18, 2013 02:00 PM
CurseDSM
Jun 17, 2012 06:15 PM
mplspilot
Mar 30, 2009 11:35 AM
