HKS vs Stock exhaust
Since I'm a grumpy old man now I decided to pull the Hks Hi power exhaust and swap back to the stock catback. I have to say its fantastic driving to work and being able to have the radio on 10 instead of 40
Was kinda bored so just figured I'd show a comparison in case someone else maybe wanted to swap back to stock and see what kinda losses they could expect. This is a mild tune on 93 octane.
The butt dyno showed about a 15-20 hp loss on the top end, the spoolup seemed about the same, so I decided to do a couple VD runs and see the difference.
Red is HKS Hipower and the other is the stock IX catback. Both with the buschur 3" downpipe and megan resonated test pipe. Both on the same exact tune.
The VD seems to confirm what I felt, I was actually fairly surprised at the lack of power loss, though this could be due to slightly varying outside temps (it's probably 5-10 degrees cooler now on the stock catback). The boost dropped 1-2lbs for the most part but not getting any knock so far.
I'm also going to run it on E85 and see the difference while running some high boost and I'll post those results as well.
UPDATE:
Here is the E85 tune with the comparison, can definitly see the stock catback struggling at higher rpms, what is still kinda weird is the lack of loss down low again. I also used a 15 degree temp correction on these as well which is probably more than what the temp variation really was. Again this is on the same tune.
I'll also be adding a mufflered electric cutouted test pipe for when I feel like being juvenile
UPDATE:
Surprising, I remember seeing more gain from a catback at these power levels. I really suspect the outside temp/humidity because: from 4500 to 5500 rpm for example, you have more boost, a 3" CBE and torque is the same than less boost and stock CBE. This isn't really possible IMO.
I thought it a little odd as well, but it also didn't feel like it lost any bottom end, felt like it lost a bit uptop which is kinda what the dyno shows.
But your right with a couple lbs less boost I would think that certainly I would lose some torque.
I have a BLITZ Nur Spec cat back and I couldn't drive the car to work because of the drone. So I found a simple solution without losing any power by switching the muffler to a Varex 3" Muffler with electronic actuator.
With the muffler in closed position, it was like I was driving my girls Yaris
And with a press of a button, I can boost all I want.
Anyway I thought I would share with those looking for a solution.
And with a press of a button, I can boost all I want.Anyway I thought I would share with those looking for a solution.
FS[SouthEast]: Mivec Valve cover, COP, Ingalls, Valvesprings,and more
90zcrex
31
Nov 1, 2014 11:09 PM
