Stock Block HTA86 madness
Old Jan 20, 2014 | 01:00 PM
  #31
EVO(boss)'s Avatar
great numbers on sexy car .. good luck
Old Jan 20, 2014 | 01:13 PM
  #32
Hołek's Avatar
Beautiful is the first photo
Old Jan 21, 2014 | 05:40 PM
  #33
Blue91lx's Avatar
Are you on stock fuel lines? If so, that's damn impressive in all aspects of fuel.
Old Jan 21, 2014 | 06:13 PM
  #34
04slowevo's Avatar
He is on stock fuel lines and stock fpr. Just some FIC 2150cc and walbro 450LPH.
Old Jan 22, 2014 | 02:08 AM
  #35
WikdEvo's Avatar
^^ exactly. The 450 is also hardwired. I drilled the siphon out to 9/64
Old Jan 22, 2014 | 02:37 AM
  #36
tscompusa's Avatar
Originally Posted by Tom Stout
Hmm I wonder if it is actually.
https://www.evolutionm.net/forums/ev...mph-traps.html
631 on that mustang is about 720 on a dynojet, so you got a ways to go yet.
Old Jan 22, 2014 | 04:59 AM
  #37
d-bo's Avatar
Originally Posted by tscompusa
https://www.evolutionm.net/forums/ev...mph-traps.html 631 on that mustang is about 720 on a dynojet, so you got a ways to go yet.
Do you happen to know the weight of this car ? I'm trying to see how much more weight I need to take out of my car lol. And what power level is needed to get around 10.0-10.2 stock block ?
I think I am around 2850/2900 now. For reference I trapped 127 on 25psi 93 Oct standard 35r previously (car was about 250lbs heavier I believe)
Old Jan 22, 2014 | 05:11 AM
  #38
st0mp860's Avatar
Dang, making me feel like I should just keep my stock block and not build it!
Old Jan 22, 2014 | 06:05 AM
  #39
Ev0ikon's Avatar
Only if you could afford a big rebuild. Ted B used to compare it to jumpers that waited until the very last second to pull their parachute.
Old Jan 22, 2014 | 06:48 AM
  #40
tscompusa's Avatar
The weight is in the thread there on the dyno graphs. That car varied from 3100-3200lb with driver.
I cant answer the ET question accurately. There are to many variables. A full weight car at 700whp dynojet should have no problem with low 10 sec passes though.
Old Jan 22, 2014 | 07:08 AM
  #41
d-bo's Avatar
The weight is in the thread there on the dyno graphs. That car varied from 3100-3200lb with driver. I cant answer the ET question accurately. There are to many variables. A full weight car at 700whp dynojet should have no problem with low 10 sec passes though.
Ah I forgot about the weight on the graph. I noticed some times when others post them they aren't even close to accurate weights so I didn't know if the weight was the car itself, or if there are multiple passengers or something during time of the graph. I should have figured yours would be closest. Thank you !
Old Jan 22, 2014 | 07:15 AM
  #42
way2qik's Avatar
^^^^exactly right. 146mph is the tell...
Tom Stout, your car at your power level on a DJ will probably trap in the 135mph range. Turn the boost up to 40-44psi range and you'll be in the power range of the car tscompusa just linked.
Old Jan 22, 2014 | 12:27 PM
  #43
WikdEvo's Avatar
haha.. i'm not chasing any records or anything, just having fun with the car.
On the log posted there were 3 people in my car with a few things in the trunk. The weight was pretty accurate.
With me being on stock tranny i'm gear/rev limited to 8000-8500 anyhow. somewhere around 135 i think.
Old Sep 2, 2014 | 04:22 AM
  #44
SiriusEvo's Avatar
Veteran: Army
How did the car hold up over the summer?
Old Sep 2, 2014 | 05:48 AM
  #45
WikdEvo's Avatar
Back in April I installed a twin disc clutch, 3.5" exhaust and a 3" uicp. Shortly thereafter the #1 rod went through the block. The car now has a built motor and will be getting retuned very soon.
