Andre's 672whp Twin Scroll S362 FMW
Old Jan 31, 2014 | 06:47 PM
  #31
doghouse's Avatar
Will be tuning worst case march . I will post the dyno chart or video from inside car while making some pulls
Old Feb 2, 2014 | 09:33 PM
  #32
mitsubeastlee's Avatar
Originally Posted by doghouse
This is my Borg Warner k31 which has 71mm inducer and 101mm exducer compressor wheel same as s471. I am on wastegate spring at 1 bar and I open the wastegate at 5500rpm in 3rd. I will add another spring soon and a boost controller and see what happen. 2.0 engine
Holy jeez that's a big turbo!!!!
Old Feb 3, 2014 | 08:18 PM
  #33
Beemen550's Avatar
I currently have this turbo also, I'm hitting 90% duty with a 2.3 e85 1600cc and around 26psi
Old Feb 4, 2014 | 11:22 PM
  #34
ILoveAWD's Avatar
What fuel pump setup are you running?
Old Feb 4, 2014 | 11:23 PM
  #35
ILoveAWD's Avatar
how much did it put down?
Old Feb 5, 2014 | 03:49 AM
  #36
Beemen550's Avatar
it was a 255 in tank and a 255 inline, fed by a -8 from tank to rail, going with a twin in tank this time around
also the car was tuned by Forged Performance but the invoice wasn't in my name so they won't release me any real info or graphs, call em and tell them your Garrett Wade and u need info on your car that was tuned there Nov 2012
Old Feb 5, 2014 | 03:54 AM
  #37
Beemen550's Avatar
think I will be trying out the new 64.5mm s300sx fmw this year
Old Feb 5, 2014 | 04:53 AM
  #38
flabber's Avatar
Subscription for info on bw turbo
Old Feb 8, 2014 | 06:26 PM
  #39
doghouse's Avatar
should spool nice
Old Feb 16, 2014 | 08:55 AM
  #40
Beemen550's Avatar
was able to get a graph from them, was told this was on gate pressure, 21-22psi and they tried to push it farther but my exedy triple carbon was on its way out and was slipping
Old Feb 16, 2014 | 09:39 AM
  #41
el.guerrero's Avatar
which gear for the pull sir?
Old Feb 16, 2014 | 10:10 AM
  #42
d-bo's Avatar
Does a nice job holding torque all the way
Old Feb 19, 2014 | 07:37 AM
  #43
Beemen550's Avatar
not sure on that one
Old Feb 19, 2014 | 08:48 AM
  #44
JohnBradley's Avatar
Beemen, this was an S362 also or after you switched to the bigger compressor wheel?
Old Feb 20, 2014 | 06:13 AM
  #45
Beemen550's Avatar
yes the s362 62mm, I haven't tried the 64mm yet
