Evo 8 help with goal?
When you get a sec (did this during my first oil change) you should pop off the rubber (circular) inspection cover window and see if you can tell what color the face plate of your clutch is. This may help you identify what you have and whether you need to change it at some point on your quest to 450hp. Good luck
With aggressive cams, proper bolt ons and e85 you might make 450 on a 9.With a green, bbk full or ef2.5 you will definitely hit it if you do it right. No need for anything bigger than that really.
I would probably recommend a walbro 400 (4XX whatever), the new FIC 1050SP's, head studs, a new head gasket (might as well while you're in there), and an EF2.5 turbo. The EF2 would do it, but you don't loose much for spool going to the 2.5, and the 2.5 would be much more comfortable there.
I can hook you up with a package deal on that stuff as well, feel free to shoot me a PM for pricing!
AllDayAnthony
Apr 11, 2015 03:28 PM
nzevo8
Sep 20, 2014 04:51 AM
jay777
23
May 15, 2013 06:53 PM
