evo 9 98% at 20psi
Old May 8, 2014 | 01:32 AM
brusinn's Avatar
evo 9 98% at 20psi
hi, im mapping friends car and injector dutycycle is at 98% at 7200rpm
boost is set at20 psi, tapering to 18psi
i think thats pretty low boost for 98% dutycycle.
the car has stock fuel pump.
is it normal or is the boost gauges showing lower than actual boost ?
thanks
Old May 8, 2014 | 04:37 AM
meckert's Avatar
Could be the stock pump which flows the least of the EVO's causing much of the issue although my guess is while you will see a difference until you add a pump and injectors you will still have a problem.. You usually try and hit no more the 80% DC to keep all things under control.
Old May 8, 2014 | 05:35 AM
SmoothCTR's Avatar
I thought the evo 9 pump flowed better than the 8 ?
Old May 8, 2014 | 01:52 PM
slowsrt4:('s Avatar
yeah stock pump, I wouldn't raise the boost on a 8 or 9 without at least doing a walboro
Old May 8, 2014 | 02:48 PM
JohnBradley's Avatar
Stock pump is old, the stock filter assembly is probably old and can be an issue. Doubtful it will need injectors more than it needs a pump. The O-ring is torn, the cuff is missing, etc.
Old May 8, 2014 | 03:20 PM
Bhsj13's Avatar
yeah the stockers will not flow much more than that. just get a wally and injectors.
KevinD
33
Jan 16, 2017 01:19 PM
tscompusa
Feb 26, 2016 11:50 PM
thundrflsh24
For Sale - Cars For Sale
Jan 5, 2016 09:19 AM
thundrflsh24
Nov 8, 2015 09:47 PM
mnr12
10
Aug 31, 2015 09:59 AM
