My 2.2 4G63/ 6466 Build
Subscribe
Oct 13, 2014 | 08:58 AM
  #46
Quote: With the car strapped down, you can still see it squat! Must be nasty!
Its def a fun car Jon, lol.
Reply 0
Oct 19, 2014 | 10:12 AM
  #47
So you went with a 94mm crank, 156 rods, and the 2.3 Pistons so the wristpin would line up? I'm trying to confirm to tell my builder. Thanks in advance!
Reply 0
Oct 22, 2014 | 08:26 PM
  #48
Quote: So you went with a 94mm crank, 156 rods, and the 2.3 Pistons so the wristpin would line up? I'm trying to confirm to tell my builder. Thanks in advance!
2.2 cp pistons
Reply 0
Nov 8, 2014 | 02:59 AM
  #49
Awesome build I'm thinking of the same when I build mine again. Only problem is I may have to shave block and head and not sure if 156mm rod will fit. Currently have Tomei 2.2 (150mm rod)
Do you know how much you shaved off your block and head?
Do you think I'll fit 156mm rods in my setup if I shave block and head again? I've shaved it once before. Thanks
Reply 0
Nov 11, 2014 | 10:39 PM
  #50
Nice build. Clean car, nice setup all around. Weigh reduction is nice because not just the extra HP, but it's slightly easier on the driveline too. Sweet ride!
Reply 0
Nov 12, 2014 | 09:28 AM
  #51
Quote: Awesome build I'm thinking of the same when I build mine again. Only problem is I may have to shave block and head and not sure if 156mm rod will fit. Currently have Tomei 2.2 (150mm rod)
The 156mm rod is a direct fit with cp 2.2 pistons. My head has been decked and oringed my block was not decked.
Reply 0
Nov 12, 2014 | 09:30 AM
  #52
Quote: Nice build. Clean car, nice setup all around. Weigh reduction is nice because not just the extra HP, but it's slightly easier on the driveline too. Sweet ride!
Thanks man, it's been a long road!
Reply 0
Nov 20, 2014 | 10:54 PM
  #53
Have you taken it to the track yet?
Reply 0
Nov 24, 2014 | 05:27 PM
  #54
Quote: Have you taken it to the track yet?
NO not yet im actually swapping from a ACD case to a non acd case with a wavetrac LSD in the next few weeks. So the car will be down till closer to the beginning of the year.
Reply 0
Nov 30, 2014 | 06:27 AM
  #55
nice build
Reply 0
Dec 3, 2014 | 09:15 PM
  #56
Quote: nice build
Thanks man!
Reply 0
Sep 5, 2016 | 09:19 AM
  #57
have you taking it to track yet ? and how does it drive in traffic ?
Reply 0
Oct 10, 2016 | 12:16 PM
  #58
Badass build man!! So you ended up making 900whp? What changes were made from the 750whp pull? Also What psi did you end up going to get 900? I'm just finishing up my 2.3 6466 build and trying to cover all bases before getting tuned. Looking for 800whp my self or anything above 😬
Reply 0
Nov 7, 2016 | 01:33 AM
  #59
Quote: Badass build man!! So you ended up making 900whp? What changes were made from the 750whp pull? Also What psi did you end up going to get 900? I'm just finishing up my 2.3 6466 build and trying to cover all bases before getting tuned. Looking for 800whp my self or anything above 😬
I have a 2.3L / 6466 build and currently making 720whp on ~36 psi. I do have a restrictive exhaust and waiting to install a few things to turn it up.
Reply 0
Nov 15, 2016 | 12:14 PM
  #60
Great looking setup and power, I can't wait until mine is done!
Reply 0
