TSComptuned / 2.4LR FP Black Stainless SS housing GSC R2 Cams 93octane | 588/478tq
Can you explain the catch can routing? Mine just has one from each side going to the same can and then it dumping down to the ground instead of a little VTA filter on top.
Did you remove the PCV valve? I just have, like i said abov,e one from the rear part of the valve cover(removed pcv) and the side of the valve cover running to one catch can. Do you ever push out your dipstick? Hows quickly is that can filling up? Mine fills up every 4000 miles. Thanks for your help. Maybe I should invest in an oil cap vent too.
The rear PCV is removed. It used to push the dipstick out but after the Vent and the spring on the dipstick it hasn't. I have never actually filled mine up? I draining it out from time to time but never allowed it to fill up.
Ya the oil cap vent is extremely convenient. I'm going to replace the baffle inside of it to a different type of mesh.
that is very nice peak numbers for pump gas. very nice actually.
but.
the low end is terrible. the spool is 500 rpm slower than typical for a 600ish hp black on a stroker. found several blacks (pump and e85) making 400tq 600 rm quicker. from these results I would say this should deflate any hype that this new housing is a improvement across the board. these look like the typical expectation of sacrificing spool for better top end power. TS to open scroll.
but.
the top and end numbers are brilliant but i have the same problem here with the ss house green and black the spool up late quite a few 100rpms and before 1000 rpm from full spool up missing a lot of torque, typcal garrett style .
i like more the mhi house .
Please do a 93 tune on this car! I'd love to see what it can do compared to a pump 3586 set up or the previous black numbers. It would almost be a direct comparison if you plan on using 93 right?
What will be more interesting to see is how it spools vs the fp black.
We will tune it on 93 first. Unfortunately no it wont be a direct comparison because weather is going to get colder. It already has started to now. But we can figure out the differences in temps based on the dates the runs were made with time stamps and deduct it.
Goodluck fellas.
