Evo 9 mr tuned results on 91 oct
Old Sep 29, 2014 | 02:51 PM
jaime8754's Avatar
OK HERE MY RESULTS FOR MY TUNED I JUST HAD DONE A FEW WEEKS AGO. I FEEL THAT THE NUMBERS A BIT LOW. NEED SOME OPINIONS.
CAR: 2006 EVO 9 MR
WITH 29K MILES
MODS:
AMS FMIC
AMS UPPER PIPES
AMS LOWER PIPES
AMS DOWNPIPE
AMS TEST PIPE
AMS EXHAUST
ARP HEADSTUDS
GSC S1 CAMS
RC 1000cc INJECTORS
WALBRO 255 FUEL PUMP
GRIMSPEED 3 PORT MBC
K&N CONE AIR FILTER
TUNED ON 91 OCTANE
THE RESULTS 286WHP/ 286 TQ
TUNED ON A DYNO DANAMICS, SHOP SAID IS A LOW READING DYNO.
ARE THESE NUMBERS CORRECT FOR ALL MY MODS. PLEASE ADVISE. THANKS
Old Sep 29, 2014 | 03:04 PM
e_kobz's Avatar
CAR: 2006 EVO 9 MR
WITH 29K MILES
MODS:
AMS FMIC
AMS UPPER PIPES
AMS LOWER PIPES
AMS DOWNPIPE
AMS TEST PIPE
AMS EXHAUST
ARP HEADSTUDS
GSC S1 CAMS
RC 1000cc INJECTORS
K&N CONE AIR FILTER
TUNED ON 91 OCTANE
How many lbs of boost?! 20?!
Old Sep 29, 2014 | 03:12 PM
hmoob_evo's Avatar
That looks about right. My brother evo 8 with tbe, mbc, stage 2 comp clutch, 24 psi, pump 93 made 240 on the heart breaker dyno dynamic.
Old Sep 29, 2014 | 04:56 PM
jaime8754's Avatar
I was told it spike at 25 then drop to 20 psi.
Old Sep 29, 2014 | 06:18 PM
Hookah Bazooka's Avatar
Someone correct me if I'm wrong, but aren't those numbers the same as factory from the crank?
Old Sep 29, 2014 | 06:26 PM
jaime8754's Avatar
Originally Posted by hookah bazooka
someone correct me if i'm wrong, but aren't those numbers the same as factory from the crank?
well they are close but these numbers are to the wheels.
Old Sep 30, 2014 | 02:47 AM
CT9A PR's Avatar
Dont those read 12% lower so its barely 310-320 whp on a dynojet?
Still a little low get a retune
Old Sep 30, 2014 | 03:08 AM
Jp7's Avatar
Jp7
I'd say your numbers are right where they should be for that fuel.
You are using 91 octane (ewww gross)
Why not go with E85? Any tuning you do with 91 octane will not feel any different. E85 will feel much different (way more torque)
Torque is what you feel, and what makes the car fun.
Old Sep 30, 2014 | 11:47 AM
Aby@MIL.SPEC's Avatar
DD #'s vary a bit, anywhere between 12 - 18% different from a DJ.
ask if they have run any stock cars across their dyno & if so, what was their max power #.
do the math relative to the published crank #'s, to see where you car would be when doing similar math.
if the dd you were on @
12% = ~320whp / DJ
18% = ~337whp / DJ
it would be better to see a boost trace...
what bov are you running?
Old Sep 30, 2014 | 11:56 AM
blackoutVIII's Avatar
CAR: 2006 EVO 9 MR
WITH 29K MILES
MODS:
AMS FMIC
AMS UPPER PIPES
AMS LOWER PIPES
AMS DOWNPIPE
AMS TEST PIPE
AMS EXHAUST
ARP HEADSTUDS
GSC S1 CAMS
RC 1000cc INJECTORS
K&N CONE AIR FILTER
TUNED ON 91 OCTANE
Sounds about right, I have similar MODS, different brand. The only MODS you have over me are FMIC, Fuel injectors, and Boost controller. The only MOD i have different from yours is the intake and CAMS. I spun the heart break Mustang Dyno at 296 hp AND 301 Tq at 23PSI.
Old Oct 1, 2014 | 12:20 AM
jaime8754's Avatar
Originally Posted by aby@mil.spec
dd #'s vary a bit, anywhere between 12 - 18% different from a dj.
Ask if they have run any stock cars across their dyno & if so, what was their max power #.
Do the math relative to the published crank #'s, to see where you car would be when doing similar math.
If the dd you were on @
12% = ~320whp / dj
18% = ~337whp / dj
What bov are you running?
i was told the dyno reads 16% lower than dyno jet.
Im running stock bov. I was told not to upgrade unless i upgrade turbo.
So that said i calculated 332whp on dj. Good or can i do better?
I didnt do a dual map because where i live i cant get e85. I would have to drive 1 1/2 hrs to buy.
howell
Jun 2, 2011 05:38 AM
