Round #2 TSComptuned 2.4L Buschur FF 6466 GSC S3 E85 32psi through 38psi
TSComptuned 2.4L 9.7:1 - Half Filled
TSComptuned cylinder head (Buschur port/polish/mill/oring)
Buschur Forward Facing 6466 Turbo kit (.82 AR vband)
Buschur Double pumper
Buschur Race FMIC
Buschur 3" Vband downpipe
Buschur Lower ic piping
Cobb 3" catback exhaust /w testpipe
GSC S3 cams
FIC 2150cc injectors
-8 AN Goodridge 910 kevlar feedline
Stock feedline as return
Fore Innovations Inline fuel filter
Map Rev 3 Ported intake manifold
Full Blown 70mm TB
ETS upper ic piping /w Tial Q bov
Hallman Pro MBC / Grimmspeed 3 port
Driveshaft shop carbon fiber driveshaft
Shep racing ultimate ratio transmission /w 4.11 FD
Tephra v7 Speed density
Graphs: (2 passengers + me driving + my weight reductions)
First graph displays the lowest boost vs the highest boost:
2nd graph displays various pulls from lowest to highest:
Outside temp during pulls mid to high 40's. All pulls on graph done in 3rd gear.
LATEST UPDATED RESULTS on 93oct and E85 in summer temps:
LATEST ENGINE BAY PIC:
2-3 at wastegate pressure (752WHP):
Track results @ 780WHP (44mph back half (First slip car wouldn't go into 4th gear):
Buschur Race FMIC
GSC S3 cams
Full Blown 70mm TB
Thanks man. You have a nice setup yourself as well.
Thank you Chris.
Thanks Ron
Ya I will take you for a ride.
Haha. Yes 3rd gear, but remember 4.11 Final drive so its like a 4th gear pull on a regular final drive i think.
Thanks Freddy. I hope so. I need to do some testing before i can verify its ready for track 100%. Ran into a little issue i will post in 2nd response after commenting here.
Thanks You mean HG wise? haha. Ya no ****. That's the only thing I don't like about this block. I think I'm gonna throw that 4g63 block in the car eventually.
Thank you Chris.
Thanks Ron
I took the car out today and now its blowing out spark. Gonna try fresh plugs first, if that doesnt work I guess its time for a CDI ignition.
I pulled all the plugs, they definitely looked rich, and there was fuel on the pistons. Running the car and boosting it with 10.6 AFR played its toll on the plugs.
I run BPR8eix i gap very tight. This ignition system has never really gave me issues, and I owned it since 2009 or so (sparktech non cdi).
I did a compression test also while I had the plugs out since i never did one before after rebuilding the engine.
It came back better then I even expected, so I am really happy about that. Every cylinder has 170psi+ of pressure with a fully cold engine.
I took it out mainly to get another video for people to see it at 810whp, but the video shut off the first time in the middle of the pulls.
I also experienced some weird voltage issues last night when I was tuning the car. The lights were dimming and stuff was clicking and going nuts at idle, so i was kind of not trusting the battery either. Its a brand new yellowtop. In boost its got 13.5 volts, at idle with headlights, heater, and radio on it is only idling at 12.2 volts though. I could of sworn it was 14 volts at idle before no matter what load was on the car.
This alternator had a half quart of oil come out of it before, so maybe its crapping out.
Shouldn't the alternator draw 14 v if its healthy even with a crappy battery or am i wrong? I know some cars can stay running with just the alternator and the battery unhooked.
Either way heres the video where it shut off on me. Stupid iphone.
It misfired in the vid also but cant really tell. It triggered the knock light though.
If new plugs fix the issue Its going to the track most likely Wednesday if weather is ok.
2nd gear misfire in progress - YouTube
My BR8s were causing a break up the other night when we were on the dyno. #2 was running rich. We gapped them down hella tight and they worked fine. I'm thinking its about time for a CDI system myself. I know I'm maxing out the COP and need to move on to spark tech. I hope you find a cheaper fix than CDI ignition id love to follow suit.
The car was 14v at first, then 5 min of idling it dropped to 11v. The alternator is just not working properly.
I know this isn't something that's recommended, but I also disconnected the negative terminal with the car running, and the car instantly shut off. I had a few friends do the same, and their evos stayed running, so I know my alternator is shot.
Heres a picture of how tight I gap my plugs. Probably similar to yours.
I am just going to get a new OEM or are you recommending me to get more then OEM AMP? I thought I read bad things about to much amps in these cars somewhere.
I really wanted to go to the track Wednesday, but I don't think I can now. Thats why I went and rushed to get a new battery local instead of saving myself $30~ from getting it from amazon.
I was having the exact same issue and thought it was my alternator, however it turned out to be my power wire going to the alternator had corroded badly and wasn't making a good connection inside the terminal (I replaced the stock wire with a heavier gauge when I rebuilt the engine and soldered it, the solder just didn't hold)
It was hard to diagnose because the heat shrink kept the wire in place, but once I bent the terminal it just kinda fell apart.
Also, I sent you a message about finishing my tune, not sure if you got it.
