e_kobz's FP 71HTA stock block/head/cam Evo IX - 450/400 on E85 @ 31psi
#151
Hey, I'm the other TT3 Evo in NASA-SE moving to the 71HTA Shaun was talking about. And beware what he says here about surge. Got mine on this past weekend. Here is what happening on 4th gear pulls:
It's doing it some in 3rd gear, but 4th gear is bad. Sounds like an air cannon blowing off rapid fire. Called FP and spoke to Robert after Shaun told me what was going on. Surge is bad enough to stall the MAF readings for a split second (near zero load). Just ordered the flow advancement cover to install. That's a 28psi peak in the graph. The ugly line is 1byte load.
Power Mods:
Stock Block Evo IX
Tomei Poncam R's (270's I think)
MAP Beehive Springs
FUll 3" TBE with test pipe
MAP O2 Housing
Ported Stock Ex Mani
ETS UICP, LICP and 3" Intercooler
ETS Intake
Walbro 255
RCE 720's
Grimmspeed 3-port EBC
Turbosmart WGA (18 Psi)
APS Twin Vent BOV
Dialing down the boost ramp is something Robert also mentioned, instead of the new cover, BUT, I am trying to keep up with the local C5 guys. I want the boost to hit hard and fast, get me on torque asap. So a cover it is.
Power Mods:
Stock Block Evo IX
MAP Beehive Springs
MAP O2 Housing
ETS Intake
Walbro 255
RCE 720's
APS Twin Vent BOV
How do you like the Poncam Type R's?? I am strongly considering them but have not found a tremendous amount of user feedback
#152
Good data, I'm going to be using the anti surge cover with mine to try and keep it from surging, and also be taking it a little easy on torque in the midrange to keep the rods happy.
On the power vs torque thing. My tune will end up in the 360-365 awhp range. I run NASA TT3 and given the car's current weight, I have to come in at the target power to weight ratio. So I want it pulling hard somewhere between 3500-4000 rpm's (torque), then dropping the torque curve vs RPM's as it climbs to end up right on my PWR number.
And yes you can make that 360-365 on the stock turbo. But doing so (on pump gas) puts you into running the turbo at the edges of it's limits. Doing lap after lap on track, this is what follows:
#153
We all know the 71hta is a turbo that spools as fast as a stock unit and flows a great deal more air. As you go up in cam size you increase the volume of air that can be packed into the cylinder which also increases the volume of air that must be pulled through the 64mm opening. At a certain boost pressure, depending on the cams, the volume of air that the cylinders require will over run the speed at which that air can enter the inlet. Speed and volume increase, chances of surge increase.
It seems that a stock cam car that limit at “normal” peak boost is around 25psi, on a mild cam car it’s around 20-22psi, and on a Kel272 or S2 car it’s between 15-17psi.
The reason why your surge issue with the stock turbo was lessened is because the S2's delayed your spool by 250rpm which slowed the rate at which the air was pulled through the inlet enough to keep it stable at the same boost pressure.
#154
I'm glad you're enjoying it so far, I hope the surge cover eliminates all of the surge for you, I think I'll be ok on the surging front but we'll see when we hit the dyno. My goal is to get the car to ramp to around 25-26psi (stock wga and ebcs) and hold it to about 7500 so the car has a really linear powerband. I think a set of cams will help carry the power up top better too. I really would like a car that makes around as much torque as the stock 9 Turbo can in the midrange, but also pulls hard to 7500.
#155
I'll do a max effort pump gas tune once the surge issue is sorted just because I am curious what the setup will make. Then I will dial it down to what I need for TT3. From what I am seeing so far, I suspect the Tomei's and the 71HTA will make for a solid 400/400 pump gas car with a broad fat powerband.
#156
Well as you can see, the Tomei's open the car up enough that it shows no signs of dropping all the way to 7500 already. As far as spool, I have to get the surge issue sorted before I can lean out the tip-in and do some tuning in that area.
#157
#161
Christian did this on 98 octane for me
71hta
2.2 jun
m2 cosworth
buschur fmic
muse uicp
muse luicp
tial blow off valve
Car was a torque monster tuned by pure drive performance
#163
34psi? That CHRA hates you...
#164
Hell yeah been running for a year and sold her off
Car is prob on the equivalent to 95 octane us
car was makin 420 torque and 390 whp consistantly would of loved to put E85 or C16 on it.
My new Evo 8 with a Kanigawa 25G picked up 100 whp on race gas alone.
This one should of been good at least for 50 more whp.
#165
So far so good. just getting started on getting a tune on the new setup. Even with pretty conservative WG duty cycles (still lots of boost taper) and pig rich it runs strong all the way through 7500. I've put any further tuning on hold pending the new cover. When the load goes from 290-0-290-0-290 during that surging the ECU is grabbing timing and AFR values from all over the place.
When that happens, you just cut the rest of the volute out, get a new turbine, and put it back together..
