Evo IX RS - Stock block / Stock cams / 6266 / E85 @ 32.7psi | 10.76 @ 136.17
A 4.11 and a 2.0 will slow the car down unless its making big power.
Once the car is moving the 4.11 makes the car more civilized to drive .
Gets better mileage,cruising at 80mph is 3000rpm or so.
Decide on what tires you are going to run on the street/track and what your end goal/RPM in the 1/4 mile is and build the trans around that. The evo 9 first and 4.11 would be too tall. If you plan on staying with stock sized(25.5") tires or taller the evo 8 3rd/4th gears work well on the stock FD and evo 9 first gear. If you are going to run a shorter tire then you may want all evo 8 ratios and a 4.31. If you are going to do a stroker then a 4.11 and evo 8 ratios work well. You can use Jacks trans calculator page and then add/subtract tire size %.
I'm currently running short tires on my car and the math worked out to be 3% taller then stock with a 4.11 . It is much faster then the 8% taller setup but you have to shift much more around town then with a 25" tire (8% taller then stock with a 4.11)
My current setup should go 133@8000rpm and the 25" tire should go 140@8000 IIRC. I've got a small turbo so it doesn't make good power past 8K
Having two sets of wheels is nice. You can have a stock FD and street tires and then 26" tall tires for the track. Best of both worlds if you are into drag racing.
Well i finally got to take the car to the track! The Street Car Takeover was in town and i figure why not a better time to make some passes. It was down for 2 months from Nov-Jan getting a rebuilt trans with an evo 8 4th and 5th gear along with an exedy twin HD. Other than that, nothing power wise on the car has changed. It did do way better at the track then i expected it to do. Started off with some mediocre passes trying to get the new clutch figured out but ended up with many 10 second passes then ended up doing a 10.7@136 after i dropped the tire pressure down to 25 psi. This was done on Bridgestone Potenza RE760 245/45/17 street tires. Not bad for a stock longblock just shy of 103,000 miles.
Ive been waiting a long time to get back to the track. And im sure this is the last pass the stock motor will see being that me and Tom have been discussing a 2.0l LR build which should happen this summer hopefully.
Pics attached below
TSCOMPTUNED FTW!
Pics attached below
TSCOMPTUNED FTW!
