600whp on a single 450 with e85
Old Mar 19, 2016 | 04:45 PM
STIbyebye's Avatar
I've seen a few threads and spoke to a few big names in the evo world, I'm switching to e85 and want to make 600wheel I'm running a built 2.4 custom apexi turbo kit 3" open exhaust, gsc r2 cams, curt brown head/intake/tb 4" Ets front mount,buschur cop kit on speed density i picked up fic 2150s, the 450 with stm rewire kit. I was told I could make 585wheel with the fuel pump and the rewire do you guys agree and what would I need to hit the 600 If not possible.
Old Mar 20, 2016 | 09:25 AM
lostsoulsevo's Avatar
Dyno jet or mustang dyno numbers? You can make over 600 on a dynojet. But if you have a built motor and supporting mods just go with a double pumper.
My 450 maxed out at 520 on a mustang dyno and it wasn't rewired.
Old Mar 20, 2016 | 02:14 PM
Chiroke666's Avatar
Honestly I would skip that and go double pumper. Your going to upgrade that eventually. At least I'm never "done"
Old Mar 20, 2016 | 02:40 PM
STIbyebye's Avatar
Well it's on scat h-beams right now so I don't want to go ***** out with it. In the winter I'm probably going to go with a english 2.2 or buschur 2.3 shortblock that way I can wind out the rpm more .I've been told to not turn it past 8k right now. I have a t4 divided top mount manifold that's waiting to get a 6466 on it so I'm gonna shoot for 800+whp on the new shortblock. But for right now I want 600wheel anything above that is a bonus to me.
Old Mar 20, 2016 | 02:43 PM
STIbyebye's Avatar
It's an awd 5000-fx dyno that's the closest to me tscomp and buschur are about 3-4hrs from me
Old Mar 21, 2016 | 11:46 AM
Turndown's Avatar
Veteran: Army
You could always do a kenne bell BAP and you could easily get 600+ out of it
Old Mar 22, 2016 | 03:12 PM
way2qik's Avatar
I made 720whp on a Mustang dyno with a single 450 pump on E85. Now, this was on a Supra, but the pump will flow that amount of fuel. But, that was it. It went lean beyond that.
Old Mar 22, 2016 | 04:26 PM
d-bo's Avatar
I made 550whp on a Mustang dyno and trapped 145mph with a rewired 450 with fuel filter removed from pump housing and drilled siphon. I ran -6 line too but I don't think that did anything.
This was 34lbs on 6466 and it held pressure fine.
Old Mar 22, 2016 | 04:32 PM
Pal215's Avatar
From my understanding, this is absolutely a 700hp capable pump on E85.
In fact, that's exactly what i'm trying to do!
I'm using the walbro 450 with the STM rewire, fuel lab FPR, upgraded fuel lines front and back, and FIC 2150cc.
At 13 volts, the Walbro 450 e85 pump flows 455LPH at 30 PSI. If my math is correct, that gives us about 7583.3 cc/ min of fuel on the pump side and 8600cc/min of fuel on the injector side.
That makes for a pretty damn matched set up if I do say so myself.
I know that people have run dual walbro 255 for a long time with a hobbs switch and the chances of pump failure are slim, but what if one of these pumps fail at WOT ?
Your AFR's hit the clouds and if you don't let off so do your rods!
That being said, I would still buy a double pumper if this pump doesn't take me to my goals.
-pal215
Old Mar 22, 2016 | 09:11 PM
STIbyebye's Avatar
-pal215
Awesome guys thanks for the response, I should have no problem making at least 600wheel on the dynojet then. I spoke with stm and they said they made 585 on their dyno which I believe is mystang. I'm just waiting on a few more parts to come in them I will update you guys with my numbers. On a side note I tested my local e85 stations, speedway and Sunoco. Coming in at e85 and e90 respectively. Is there a big difference in that percentage. Like would,it be worth getting the Sunoco blend it's just a little ways farther then speedway for me which is very convenient.
Thanks Again for all the support!
Old Mar 22, 2016 | 10:33 PM
roni4g63's Avatar
be careful with the H-beams, i know kind of OT but ask around before you shoot for that number, and goodluck bud!
Old Mar 23, 2016 | 09:21 AM
LetsGetThisDone's Avatar
-pal215
What if your single pump takes a ****? Same principle. And loosing one of the pumps in the double pumper setup is like hitting fuel cut. You know something is wrong right away, and you lift. Nothing gets hurt.
I'm not saying the single is bad, my single 450 performs flawlessly with a dual voltage rewire on a stock fuel system other than injectors and drilling the siphon to 9/64's. I'm just saying your logic on the double pumper is a bit flawed.
Old Mar 23, 2016 | 09:58 AM
Pal215's Avatar
I'm understanding where you're coming from, but wouldn't having one pump fail cause the engine to quickly die at WOT before any internal damage has taken place since it would just use up the fuel supply left in the rail?
I was thinking that having two pumps could potentially keep the engine on long enough to run super lean if just one pump failed because fuel would still be circulating.
-pal215
Old Mar 23, 2016 | 10:21 AM
I understanding where you're coming from, but wouldn't having one pump fail cause the engine to quickly die at WOT before any internal damage has taken place since it would just use up the fuel supply left in the rail?
-pal215
It would still run on one pump if one of the pump in a double pumper failed, but it's going to fall flat on its face.
I had a "similar" experience in my car. The boost reference line came off the solenoid that activates the high voltage circuit for the fuel pump. So my walbro 450 went from seeing 14v, to 8-9 volts while in boost at 6500rpms at 30psi. Car sounded like it lost 3 cylinders instantly. I lifted, no harm done. The log showed AFR went full lean. Put the boost reference line back on with 2 zipties and haven't had an issue since.
Old Mar 23, 2016 | 10:38 AM
Pal215's Avatar
I see. Well that's good to know for a future setup. It's good that you caught that voltage drop.
I remember the first time I experienced fuel cut at WOT. It scared the hell out of me. Almost like a tow truck suddenly latched onto my a$$.
-pal215
