FP Red DBB results
Old Apr 28, 2016 | 09:48 AM
LetsGetThisDone's Avatar
Purely out of curiosity, is your catch can only VTA? If it is, that is why you could be experience smoking/oil leakage issues with you FP turbo. The VTA catch can is not adequately pulling pressure out of the crank case.
Old Apr 28, 2016 | 01:08 PM
XSivPSI's Avatar
Did he say anything about having that issue? I was about to PM him to ask if he was having oil burning issues. I just got my stock turbo back on and the blue smoke is gone so I'm sending mine bb red back to FP in the next few days
EDIT: Saw the post you were referring to.
Old Apr 28, 2016 | 02:08 PM
saxon's Avatar
Yes it is, I run e85 And refuse to have those vapors sucked back in through the intake
Old Apr 28, 2016 | 02:09 PM
saxon's Avatar
Originally Posted by mrfred
Good numbers. I love the rims. 18x9.5"?
Thanks!
18x9 +35 265/35 18
Old Apr 28, 2016 | 02:16 PM
Well, there you go. Not sure what vapor's your worried about. Your leakage/smoke is likely solvable..
Old Apr 28, 2016 | 02:23 PM
saxon's Avatar
Have you ever drained a catch can that was only vta?
Old Apr 28, 2016 | 02:47 PM
My rear port (pcv port) catch can has to be drained. It fills up with E85 goop. Driver side to intake pipe never has anything in it. Only thing I ever find in the IC pipes is a bit of oil (actual oil that looks just like used motor oil). I'm not sure what your concern is.
Old Apr 28, 2016 | 05:08 PM
saxon's Avatar
The gunk I drain from my catch can doesn't look like something I want going back into my intake. You're more than welcome to do that but it's certainly not good for combustion
Old Apr 28, 2016 | 05:51 PM
Yea, I don't see how it hurts. My car mad the numbers in my sig with 26.5psi out the top. Combustion is just fine. That liquid is just fuel and a little bit of oil, and depending on how long it sits there it collects water. And the water collection what really makes it look nasty..
Old Apr 28, 2016 | 07:27 PM
Keng_v's Avatar
This car must be fun to drive.
€vo!utioN
Aug 31, 2015 05:14 PM
Spec-OpsMotorsports
Aug 27, 2015 05:04 AM
Geoff Raicer
Dec 11, 2012 05:45 PM
Kins
Jan 27, 2012 01:32 PM
