Evo 8 FP 71hta 91/E85 results
Old May 2, 2016 | 07:39 PM
evo4life94's Avatar
Evo 8 FP 71hta 91/E85 (Updated GSC S2 installed)
Well it took longer than expected but GSC S2 cams were finally installed and tuned.
91 octane, 24 psi, cutout closed and open
E85, 26 psi, cutout closed and open
New parts added: GSC S2 w/5041 springs and retainers
FP manifold
Stock catback was put back on with electric cutout in place of test pipe
Just wanted to share my results and wanted to know what you guys think. This is on both 91 octane and e85. GSC s2 cams with valve springs and retainers are next on the list.
Mod list:
Stock block and Head(Stock cams)
FP 84mm 71hta w/ 18psi wga
FP 84mm intake pipe
3" TBE
Muse 02 dump
3 port bcs
Synapse DV
Vrsf 3.5" intercooler
Muse licp
Walbro 255
RC 1200cc injectors
Evo 8 FP 71hta 91/E85 results-9f0ab4l.png
Old May 2, 2016 | 07:49 PM
ronaldo9's Avatar
Nice setup! Is e85 readily available in California?
Old May 4, 2016 | 07:22 AM
revhappy's Avatar
The stock cams are definitely hurting in the high rpms. The GSC S2s will help a lot.
Old May 4, 2016 | 08:11 PM
deylag's Avatar
Wow your setup is similar to mine. Missing a couple mods that you have that are probably holding me back. Thanks for sharing!
Old May 4, 2016 | 09:45 PM
RazorLab's Avatar
I thought you where on stock turbo?
Old May 4, 2016 | 11:11 PM
deylag's Avatar
Yes I am on stock turbo/stock cams. It was bad wording on my part.
What I meant to say was I wish I could emulate evo4life94's setup because I am only missing a couple parts to make it happen.
To be specific on the parts I am missing:
FP 84mm 71hta
FP 84mm intake pipe
Muse 02 dump
Old May 5, 2016 | 06:20 AM
[TK]'s Avatar
actually pretty similar to my mods also. I'm missing the 84mm cover and intake pipe as well as I still have the stock o2 housing. I dyno'd at 405hp 381 tq 27psi.
GSC s2 with muse o2 housing next up for me. Congrats on results!
Old May 12, 2016 | 02:58 PM
killerpenguin21's Avatar
What boost for the runs?
Old May 12, 2016 | 03:01 PM
e_kobz's Avatar
How much boost?
Old May 12, 2016 | 03:30 PM
edsct9a's Avatar
I need to get my car on a dyno to see what my numbers are. Been considering this or a Red but I think some tranny work will be needed first just to be safe.
Old May 12, 2016 | 03:56 PM
Evox2008xove's Avatar
oh ... outstanding.. i need e85
Old May 13, 2016 | 06:12 AM
[TK]'s Avatar
once you go e85... you never go back...
Old May 13, 2016 | 07:50 AM
e_kobz's Avatar
Is this a fairly conservative tune? I only ask cause on the same dyno with the same mods I made 450/400 on E85 also on stock cams. There's more to be had in your setup, unless you want it conservative
Old May 13, 2016 | 08:01 AM
edsct9a's Avatar
I would think so as I'm sure the stock turbo can put close to those numbers down but with a lot of boost. How much psi?
Old May 13, 2016 | 09:23 AM
e_kobz's Avatar
On my 450/400 E85 map I'm running 30psi tapering to 27.5psi by 7500rpm. Nasty little setup
