Car is an Evo 9, tuned by Johnson Tuning. Mods on the car are as follows:
Driven Fab EFR 7163 Vband Kit
Driven Fab 3.5" Aluminum Exhaust
Driven Fab Catch Can
ID 1300's
Walbro 450
e85
3" intercooler
Stock ECU
Curt Brown ported intake manifold
Built 2.3
- stock crank
- eagle rods 9:1
- ross pistsons
Stock cylinder head ports
- GSC S2 Cams
- GSC Valve Springs
Car made 593/583 on 36 psi before running out of injectors, bumping fuel pressure did nothing so the car was turned down a bit. What an absolute monster this little turbo is, it's quite impressive to say the least. Packs a massive punch in such a small frame.
Both Plots are on e85:
- the blue plot is 34psi peak tapering to ~30ish psi at redline.
- the red plot is 24 psi peak
Turbo kit info can be found here
https://www.driven-fabrication.com/p...band-turbo-kit
ID 1300's
Walbro 450
e85
3" intercooler
Stock ECU
Built 2.3
- stock crank
- eagle rods 9:1
- ross pistsons
- GSC S2 Cams
- GSC Valve Springs
alpinaturbo
close
- Join DateMar 2007
- LocationCalifornia
iTrader Positive Feedback100
iTrader Feedback Score(5)
Liked:54 Times in 44 Posts
What boost levels are the two curves, blue and red?
More info?
Cams,head work, motor size, compression, stoke intake manifold or porter,
LetsGetThisDone
close
- Join DateOct 2013
- LocationLas Vegas
iTrader Feedback Score(1)
Liked:1,629 Times in 1,392 Posts
Quote:
It looks like Chad's car.Originally Posted by ihockey1
Is this chad's car, if so it recently blew up
What were turbine speeds and boost at both power levels?
Wow from where I'm looking this think can safely make 500whp and spool faster than stock, is that correct? also please list a more extensive mod list
This setup is just plain nasty! Perfect for the street and a monster on the road course. Any info on the motor blow?!
LetsGetThisDone
close
- Join DateOct 2013
- LocationLas Vegas
Quote:
Lost a rod. Happened in a right hand corner, Chad is pretty sure it was oil starvation.Originally Posted by e_kobz
Quote:
Damn, thats unfortunate. Dry sump time!Originally Posted by letsgetthisdone
Quote:
Asked Chad, will update when I know more. I know high boost was up there, like 38ish psi.Originally Posted by alpinaturbo
Updated the first post with more info, will add more when I get more answers.Originally Posted by Brianawd
More info? Cams,head work, motor size, compression, stoke intake manifold or porter,
Quote:
Yeah, 7 year old motor probably didn't help the cause. Or those Eagle rods.Originally Posted by ihockey1
Turbine speeds we don't know, I don't think he has a shaft speed sensor. Asked Chad for boost levels, will report back when I know.Originally Posted by letsgetthisdone
It looks like Chad's car.What were turbine speeds and boost at both power levels?
Quote:
Doesn't spool faster than stock, but can very easily make 500+ WHP. Putting one of these kits on my Evo 8 DD.Originally Posted by suby2evo
Quote:
Oil starvation, car was on the lower boost map, lost it in a right hand turn.Originally Posted by e_kobz
Quote:
This turbo is awesome, one of my favorite options available at the moment.Originally Posted by awhit17
This is gnarly, great powerband and it isn't even the twin scroll hotside!
Car unfortunately threw a rod on low boost at the track shortly after due to oil starvation, for those that were asking.
