Reasonable numbers of a Td05 16g?!
Old Apr 6, 2017 | 03:19 PM
1MorPsi's Avatar
I am getting my Evo 9 tuned in the next month. I wanted to see what kind of numbers you think are viable given my set of mods prior to tuning, because the car is running a small td05 16g turbo as of now (guess the stock 9 popped before I got the car?) & id like to upgrade turbos right away but really don't have the cash flow as right now given I just purchased the mods listed below. Given my mods, whats some realistic numbers for the car, which will be my daily?
MODS: Td05 small 16g turbo, MAP downpipe & 02 dump, 3" STM test pipe & buschur catback, new ACT 4 puck clutch, AEM intake, grimmspeed 3 port EBC, ETS LICP, stock injectors, and 255 walbro fuel pump.
Within the next two years I plan to get injectors, intercooler, cams & probably an FP black, but want to run the car as is until then. What kind of numbers is that setup looking to make?!?
Old Apr 10, 2017 | 07:56 AM
lancerrally45's Avatar
I hit 475 tq and like 400hp on mine with a 2.4L. That was at like 34psi on high compression/e-85. Wouldnt recommend going that high. I was bored and needed a reason to swap my turbo.
Old Apr 10, 2017 | 08:21 AM
ronaldo9's Avatar
330whp/330tq more or less on a dynojet on pump gas. With E85 you can make 400hp with those mods.
Old Apr 12, 2017 | 09:31 AM
LetsGetThisDone's Avatar
Are you saying the car has an Evo 8 turbo? Because The Evo 8/9 turbo is a TD05 16g. There are just minor difference to compressor and turbine housings.
Old Apr 19, 2017 | 10:11 PM
tscompusa's Avatar
A small 16G is 4lb/min less then the regular evo 8 16g which is equiv to a evo3 16G.
RalliArtEvoVIII
Jun 25, 2005 05:14 PM
nastea
34
Jul 14, 2004 10:50 AM
