Where should I take my Evo in Orlando for Mods/maintenance/Tuning?
Ostar is a legit Evo and DSM shop. Do yourself a favor a avoid CFT they don't do decent work they will leave loose bolts and loose parts and for tuning stay away from Daniel Perez aka DMT tuning, his tunes are trash and he will disable your knock sensor to get keep pushing your car to its limits which will eventually cause catastrophic failure
I can make it run like stock on speed density with stock ecu 99% shops cant.
If MAF then no worries who does it. If you want other alternatives I can do it remote from my location if you rent a dyno locally in your area. Im sure Jay would let you rent his.
This goes for anyone on this forum or anyone with an evo for that matter world wide.
If you're doing speed density on stock ecu and care about how the car drives or want a functional car that doesn't drive like crap you better be careful.
Any tuner who can only do one thing and not the other should be looked at with caution. Its not hard to adjust or tune flex fuel on AEM series 2. That just tells me the tuner is really lacking knowledge in general altogether for AEM.
