Fuel efficiency issue
Old Jun 25, 2017 | 08:45 PM
nicklim208's Avatar
hi to all brothers and sisters out!
i have bad fuel consumption on my evo 9 rs which may or may not be tuning issue and would like to get advises from u guys.
Im running on stock engine with Tomei 270 poncams with FP red. My fuel consumption is about 6km/litre which is quite high. Need some advise.
Old Jun 26, 2017 | 05:10 AM
2winscroll's Avatar
You posted in the wrong category bro this is dyno tuning results.
Old Jun 26, 2017 | 11:24 AM
LetsGetThisDone's Avatar
What fuel are you running? That's about 14mpg. I get 10-12mpg on E85, and 15-17 on pump gas.
Old Jun 27, 2017 | 12:46 AM
RightSaid fred's Avatar
The common cause of that is a failed NB oxygen sensor.
You can check it with a voltmeter or evoscan.
Old Jun 27, 2017 | 12:59 AM
nicklim208's Avatar
im running on shell 98.
Old Jun 27, 2017 | 01:00 AM
nicklim208's Avatar
everything good on evoscan. Don't really know what other stuffs causes bad fc.
Old Jun 27, 2017 | 10:44 PM
When you say everything is good?
Do you know what to look for?
1/ max voltage of o2 sensor.
2/ Rate at which it sweeps up and down with a fast idle when it's fully warmed up
Old Jun 27, 2017 | 11:14 PM
nicklim208's Avatar
how do I check these 2 that u mentioned?
Old Jun 27, 2017 | 11:45 PM
As above when you said it was OK.
Evoscan or voltmeter.
But you've made another thread saying you've got a 255 pump and big injectors but no mention of FPR.
So you'll also have the universal problem of FPR over run which you'll find when you check the fuel pressure with a gauge.
Old Jun 28, 2017 | 04:18 AM
ApexSilverEvoX's Avatar
Sounds like a sensor for sure.
Old Jun 28, 2017 | 08:23 AM
JohnnyTSi's Avatar
This is what my fully built 2.4 gets on 92 octane:
Old Jun 28, 2017 | 08:36 AM
meckert's Avatar
Could be something as easy as a bad tune as well. If it running pig rich--likely 2-3mpg rt there.
Old Jun 28, 2017 | 09:24 AM
Biggiesacks's Avatar
have you ruled out all the generic car stuff? Air filter, spark plugs, dirty injectors, good alignment, tire pressure etc? Hell driving at highway speeds with your windows down can have a decent effect on mileage.
Old Jun 28, 2017 | 07:52 PM
nicklim208's Avatar
yes all fuel related stuffs changed brand new, except didn't check it the injectors were dirty which I think impossible.
Old Jun 30, 2017 | 07:21 AM
2winscroll's Avatar
https://www.evolutionm.net/forums/ev...ee-inside.html
