Freak stock block?
Regardless of any inaccurate information, it doesn't take a rocket scientist to understand that a Red is not capable of moving that much air at only 18psi, especially on pump gas, stock exhaust, and hardly any timing. If people continue to use his services after seeing how much of a moron this person really is, then they deserved to be burned. If he thinks posting false dyno numbers is going to help his business, he has a short career ahead of him. Not one reputable tuner out there would ever post this dyno graph because they are all smart enough to understand that something isn't right. Whether it be load issues with the dyno, inaccurate information, software problems, etc. This guy is an idiot!
This is how easy it is to manipulate the vdyno charts with no trace of it on the actual shared image:
My Evo 10, everything set in vdyno as it should be. Correct weight, correct occupant weight, correct final drive.
My Evo 10. Correct weight, correct occupant weight, changed final drive number.
I saw someone show a picture with running 32 psi. Why create a false tale except to make everyone think your some kinda super tooner lol. People in colorado drive me insane with all their super high correction factors.
If you read the fine print on SAE dyno specs.........correction factors are not supposed to be applied to forced induction and the max correction factor under any circumstances is 5%.
The whole idea of a correction factor is to balance out N/A engines so that you can determine what it should make at sea level when it's tested at altitude.
Forced induction is an "altered atmosphere"so doesn't apply.
Just like an aircraft.
VD also has multiplier you can change, which doesn't show up on the screenshot. You're supposed to use it to match your VD results with real dyno results. You can select mustang dyno, dyno jet, or enter your own number..
The title at the top changes when you do that though.
I'm going to clear this up. The people that want to listen will listen. The others will down cry what I have to say and eventually move on with their lives.
As the owner of Apex Powered this was a miscommunication with the person that post on social media outlets. The car has cams that are heavily degreed by a local shop here is Colorado and therefore lead to a really funky timing map when I tuned the car.
-The timing maps has 8 degrees of timing peak on the rom (this is why the person who posted the original post made this mistake)
-The car is actually running 19* of timing peak. This was done to keep the power up as boost tapered. 297 load tapering to 250 load.
-The Aem tru boost gauge said 18 psi however the calculation for the stock map sensor said 32
Do I believe the boost gauge? of course not. My personal VIII is running a similar setup and I have to run 31 psi on e85 to make the same power LOL.
It was a mistake that got blown out of proportion and exaggerated by the evo groups unfortunately. The post was taken down and I understand the ridicule. From the outside looking in I get it. Just my side of the story.
