Bought a used shortblock - let’s see what it’ll do...
Old Oct 10, 2019 | 09:52 AM
  #106
Bmurray's Avatar
Originally Posted by 2006EvoIXer
I have zero trust in them delivering in 3-4 weeks. I'll be surpised if they can get it back to you in 3-4 months. In reality, I'd guess 8 months, maybe as early as 6 months. Good luck.
LMAO. 8 months. Right.
Old Oct 10, 2019 | 11:10 AM
  #107
RazorLab's Avatar
3-4 weeks.... lmao.......
Machine shop alone will probably take that time.
Old Oct 10, 2019 | 02:23 PM
  #108
ncdirtrider249's Avatar
Woot!
Old Oct 10, 2019 | 08:29 PM
  #109
2006EvoIXer's Avatar
Let's see how long it takes. You have a contact.
Old Oct 18, 2019 | 06:29 PM
  #110
Shamsiel's Avatar
Veteran: Army
Are you still on the stock 4.59?
Old Oct 18, 2019 | 06:36 PM
  #111
Bmurray's Avatar
yes
Old Oct 22, 2019 | 03:55 PM
  #112
2winscroll's Avatar
What rods will you be running? The reason I ask is once you get over 800hp with steel rods it becomes paramount that the tune is perfect. If not, you will have issues like you just had, rod bearing failures. I like too see 625 bolts instead of the arp2000’s above 800 also. Just a thought.
That plug you burnt up was most certainly preignition, was it on the same cylinder you had the rod failure? #4?
Old Oct 22, 2019 | 07:15 PM
  #113
Bmurray's Avatar
decided to stick with turbo tuff rods. Was going to go aluminum rod but after some research I think the steel rods are going to best suit my needs. And no the rod spun bearing on cylinder 2 I was told.
Old Nov 11, 2019 | 03:04 PM
  #114
Bmurray's Avatar
Block is finished. Just got to finish up the head and then ship it back!
Old Nov 12, 2019 | 10:15 AM
  #115
LetsGetThisDone's Avatar
Badass man. That was quick. They must keep their custom pistons on the shelf.
Old Nov 12, 2019 | 10:19 AM
  #116
Bmurray's Avatar
What they explained to me is that they now use manley pistons. He said they the specs on them are now equivalent to the JE custom pistons they used in the past - but are available “off the shelf”. At least if I understood correctly that is.
Old Nov 27, 2019 | 07:19 AM
  #117
Bmurray's Avatar
Motor is here. Purchasing the Inline racing (huy Tran) modified oil pan / pickup. That’s all we’re waiting on then it is tune time!
couple other goodies I purchased since rebuild: - boosted fab lightweight crossmember
- stm front drag brake kit
- stm race oil cooler
- 3.5” ets exhaust
- new aem x series -30-60psi boost gauge
- new 15” wheel setup
Old Nov 28, 2019 | 05:29 AM
  #118
RazorLab's Avatar
I can't believe how quick that was. Lucky you!
Old Nov 28, 2019 | 05:42 AM
  #119
Bmurray's Avatar
haha they knocked out 3 motors for my tuner’s shop in that time span
Old Nov 28, 2019 | 09:51 PM
  #120
2winscroll's Avatar
UhOh he’s got the block o-ringed, this means only one thing...BIG POWER!
How much did they charge for the o-ring job? Is it a double groove o-ring setup with receiver groove?
Whats your HP goal?
Cheers, Steveo
